freshly redone banshee parts following are brand new and have zero hours ride time on them:hot rods crank, all new bottom end seals,clutch,clutch cable,throttle cable,graskets,pistons and rings(std bore)wiseco,carb rebuild kit,boyseen reeds,axle bearings,swingarm bearings,steering stem bearings,a-arm bushings,wheel bearings,steering stem,stator,complete wiring harness,kn filter,pro taper bars,ignition,cdi,coil,chain and sprockets coil,sprockets,chain,k.n filter,and some other odds and ends.! only flaws are the fenders are not in good shape and the seat needs the cover stapled which i am doing. i will trade for a 4 stroke sport qua.my bike still has stock exhaust on it to. .i am located in knox pa. feel free to text for pics as i have none on computer. 814-227-5479 thank you for your time.
  • 2 weeks later...
