Dented pipe repair
I picked up a set of pipes and one has a dent in it. Pretty good one too. The guy had been running them but i was going to try and fix it.
I was told there is a trick, plug the end, pressurize it and heat up the dent and it should pop out. Anyone tried this? Got any other ideas? Figured i would just cut it and reweld a peice in but any non evasive procedures would be considered first. I also herd of filling it with water and freezing it. Never tried it though.
id cut the pipe around that weld and tap it out with a mallet then reweld it. make sure you mark the pipe so you remember how it lines up
the heat method works, just do it slow and easy, not to much pressure or too much heat.
Do anything but this please, Filling with water and freezing works but you have to be careful with it.
A rubber freeze plug works well on the cylinder side of the pipe, plug other side with a way to put air into it only about 5 to 10 psi..use a torch to heat it..to much heat or to much air the plug will blow out like a cannon....works like a dream.. first time i tryed it only had a weed burner to much heat displacement and to much air, i had a big cannon the freeze plug went a half a block or so never did find it... :whoa:
I like this.. i was thinking like 50psi hha. Good thing you said something
