burhead Posted June 5, 2012 Report Share Posted June 5, 2012 I am looking for some jetting advice for my banshee with R2 pipes. I have a stock air box with a uni filter and the lid removed. Carbs are stock and it has a .020 shaved head on it. I jetted it last year and it ran well at my house ripping down the gravel road. I am at 1100 ft and the weather was in the 70s. I took it to the riding spot about 4 hrs away and it seemed doggy out of the hole. My riding area is at 1500 ft and it is sand. I am looking for some advice as to what others are running for jetting with these pipes. I am currently at a 330 main but I think when I get to the riding spot I could probably go leaner. I am also having a hard starting problem so I will be going into the carbs tonight. Any help is a ppreciated. Quote Link to comment Share on other sites More sharing options...
special06shee Posted June 6, 2012 Report Share Posted June 6, 2012 I am looking for some jetting advice for my banshee with R2 pipes. I have a stock air box with a uni filter and the lid removed. Carbs are stock and it has a .020 shaved head on it. I jetted it last year and it ran well at my house ripping down the gravel road. I am at 1100 ft and the weather was in the 70s. I took it to the riding spot about 4 hrs away and it seemed doggy out of the hole. My riding area is at 1500 ft and it is sand. I am looking for some advice as to what others are running for jetting with these pipes. I am currently at a 330 main but I think when I get to the riding spot I could probably go leaner. I am also having a hard starting problem so I will be going into the carbs tonight. Any help is a ppreciated. If those are your only mods id say your a bit rich specially at that elevation! Did you do a plug chop?? I could be wrong but id say you should be around 280-310s and a 27.5 pilot Quote Link to comment Share on other sites More sharing options...
burhead Posted June 6, 2012 Author Report Share Posted June 6, 2012 If those are your only mods id say your a bit rich specially at that elevation! Did you do a plug chop?? I could be wrong but id say you should be around 280-310s and a 27.5 pilot Yea I did a plug chop when I initially installed the pipes. I usually run a milk chocolate colored plug as that is what my polaris 2 strokes like. I'm going to see how the plug looks and how it runs with a 310. I was just curious what others had ended up with. I couldn't find alot of other posts about these pipes. Quote Link to comment Share on other sites More sharing options...
