2001 Banshee with 421 Serval Potential Part Out
I have a 2001 Banshee with a 421 Serval Engine. Located in Cleveland Ohio. If someone is interested in the engine let me know and I will part out the whole bike.
The engine was new last year in July and has about 35 hours on it. Has 150 psi compression on both cylinders.
Magna Billet Clutch Basket with Fast clutch with HD springs new this year
V force 2 reeds
Pro Design Cool Head with 22 cc domes cut for 4mm Crank
M & M 4mm Crank with long rods
Wiesco pistons
New Chain and Sprockets Last Year
30 mm OKO carbs new last year
Billet water pump
New stator
Pro circuit pipes that I painted black
Aluminum air box with dual uni filters
Dual petcock in gas tank
New carrier bearings, swing arm bearings this year
Works front shocks with reservoirs
New Tusk Nerf Bars
Trail tech digital gauge
The bike needs tie rods on one side I replace one side this year.
The cases have a little chain whack but it does not effect the engine
The bike has no title because I had to switch the frame. I do have the original frame with the title but the frame is not usable. Asking 2700 for the complete bike.
Or I may part it out if I can sell the complete engine.
Also I would consider a trade for any Yamaha or Honda 450 or a 400ex with reverse.
I have one picture from last year but I will get more together.
http://s1103.photobucket.com/albums/g464/cle_chris/
Serval says it in the topic. That's not a stock cylinder
I meant to ask if it was stock porting. Thanks for your clever response though.
