treadway Posted June 3, 2012 Report Share Posted June 3, 2012 hey every one im new to this site im needing some advice on my banshee neither side is firing i have swaped out the ignition coil and the cdi box off my buddys banshee still have nothing it dosent have tors electrical stuff on it at all. i had just washed it the day before rode it after i washed it did just fine next day pulled it out of the building started right up went to pull out and it just died. i have also checked the resistance on the stator and pick up coil both was in specs with my clymer manual i have. i have also went all thru the wiring harness wiring looks good and the kill switch and key switch checked out good when i pulled stator cover off it did have some water in it but it always does any sugestions thanks. Quote Link to comment Share on other sites More sharing options...
Nightmare Posted June 3, 2012 Report Share Posted June 3, 2012 my bike did that to me too. I let it sit for a week and it fired up around the 10th kick and started on the 1st or 2nd after that. Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted June 3, 2012 Report Share Posted June 3, 2012 Do you have spark? Quote Link to comment Share on other sites More sharing options...
Dahl87banshee Posted June 3, 2012 Report Share Posted June 3, 2012 Stators check in spec to the manual sometimes but aren't actually good. Rickystators are known for this. I would swap stators with someone or try a new one. Even if thats not it, always nice to have one laying around for when it does go out. Quote Link to comment Share on other sites More sharing options...
