banseefun Posted June 1, 2012 Report Share Posted June 1, 2012 My '01 banshee shoots a blue flame out the right exhause about 4-5 inches. The guy I bought it from hard the top end torn apart do to a busted piston so I have no idea how it ran before. I replaced the whole top end and bearings in the bottom end. The cylinders looks fine and checked out to be standard. I replaced the needle and seat in the carbs also since they wouldn't seal off. It's hard to start, won't idle figure the carbs need adjusted but afraid to let it run to long with the flame shooting out the one side. This is my first 2 stroke so I don't know much about them. Quote Link to comment Share on other sites More sharing options...
Finch Posted June 1, 2012 Report Share Posted June 1, 2012 didnt ya already post this once Quote Link to comment Share on other sites More sharing options...
banseefun Posted June 1, 2012 Author Report Share Posted June 1, 2012 didnt ya already post this once Yeah but I think i put it under the wrong area since I noticed at the top it said wanted and didn't think anyone would read it there. As soon as I figure out how to delete it I'll delete the other posting. Quote Link to comment Share on other sites More sharing options...
Finch Posted June 1, 2012 Report Share Posted June 1, 2012 Have to ask loco or maybe a mod. I've never heard of a banshee shooting flames Quote Link to comment Share on other sites More sharing options...
banseefun Posted June 1, 2012 Author Report Share Posted June 1, 2012 Have to ask loco or maybe a mod. I've never heard of a banshee shooting flames Was suppose to take it into Sandtrax here in town tomorrow but he's over books so got to check back with him tuesday. I would have never noticed it had I not be out about to go riding after dark at Little Sahara here in Oklahoma. Thought if anyone had any ideas I'd try messing with it myself some more. Just in over my head now with it. Quote Link to comment Share on other sites More sharing options...
Finch Posted June 1, 2012 Report Share Posted June 1, 2012 Not worth paying someone there easy to work on. But then again I've never seen flames bust out the vid camera Quote Link to comment Share on other sites More sharing options...
banseefun Posted June 1, 2012 Author Report Share Posted June 1, 2012 Not worth paying someone there easy to work on. But then again I've never seen flames bust out the vid camera I'll try starting it this weekend and see if I can video it. Quote Link to comment Share on other sites More sharing options...
erickson483 Posted June 1, 2012 Report Share Posted June 1, 2012 What exhaust system are you running? Is there any chance you saw sparks and not a flame? Quote Link to comment Share on other sites More sharing options...
vulvafan537240 Posted June 1, 2012 Report Share Posted June 1, 2012 Sounds cool. Video for sure. Quote Link to comment Share on other sites More sharing options...
banseefun Posted June 1, 2012 Author Report Share Posted June 1, 2012 What exhaust system are you running? Is there any chance you saw sparks and not a flame? Back half FMF and front half Paul Turner. Quote Link to comment Share on other sites More sharing options...
Jereme6655 Posted June 1, 2012 Report Share Posted June 1, 2012 mods? elevation? current jetting? TORS still connected? also do you have the choke tube in place between the two carbs? i've seen this before.....happened to my buddies bike. pulled his carbs and cleaned the hell out of them.....then tried jetting and everything else.......nothing changed it. Finally he ordered a used set of stock carbs. Threw those on and it solved the problem.....so somewhere internally in his old carbs there was something wrong. Quote Link to comment Share on other sites More sharing options...
banseefun Posted June 1, 2012 Author Report Share Posted June 1, 2012 mods? elevation? current jetting? TORS still connected? also do you have the choke tube in place between the two carbs? i've seen this before.....happened to my buddies bike. pulled his carbs and cleaned the hell out of them.....then tried jetting and everything else.......nothing changed it. Finally he ordered a used set of stock carbs. Threw those on and it solved the problem.....so somewhere internally in his old carbs there was something wrong. Was told it was bone stock when I bought it other then the exhaust which is half paul turner and half fmf. I was out in the Oklahoma panhandle with is around 2500-3000 ft above sea level. Still have the TORS on it and connected and looks like a regular vacuum hose for the choke tube. I did replace the seat and needle since they wouldn't seal off. Glad I'm not the only that has had this problem. Quote Link to comment Share on other sites More sharing options...
Jereme6655 Posted June 2, 2012 Report Share Posted June 2, 2012 You do a leakdown test after you rebuilt the top end? Quote Link to comment Share on other sites More sharing options...
registered user Posted June 2, 2012 Report Share Posted June 2, 2012 shootin flames is badass . wish mine could do that Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted June 2, 2012 Report Share Posted June 2, 2012 That's usually a lean condition if it's poping and shooting blue flames. Quote Link to comment Share on other sites More sharing options...
