What went wrong?
So I put a .035 shaved head on my shee with stock pistions and a dune port. I started out with 330 mains and 30 pilots and it was running super lean. Then worked my way up to 370 mains and 35 started turning a nice brown, then made a few more passes and came to a screaching stop. got home from the dunes and pulled it apart and found that I broke the crap out of the bottom of the pistons. What the went wrong? The plugs were looking great the all the sudden nothing. I had BR8ES plugs. any words of advice?
Thanks
Nick
Thanks
Nick
How was the piston broken? Intake side, exhaust side? Bottom under the crown? I'd guess most likely too large of a piston clearance and you broke the skirt.
:confused:
SP
Did you ever do a squish test? Compression test? Leakdown test? All of these should be done before you start running a new bike or new rebuild.
He never said it was a new bike or fresh rebuild. Only the he changed the head. At which point he should have checked the squish.
SP
these are stock carbs, I don't think I have an air leak cause I had 310 mains before head change and I was running rich. I haven't touched the internals minus getting the cylinders ported, since I was a moron and bought it new in 05. I went from 30 to 35 pilots because that is all the local shops had.
correct me if im wrong here guys.....but i was pretty sure you didn't have to rejet when you change out for more compression. I get that its always good to ceck your jetting whenever you cange something.....even if its just to make sure..... however to go up 6 sizes on mains and to go up 2 on the pilot.....makes me think there was an air leak.
