BigRed350x Posted May 31, 2012 Report Share Posted May 31, 2012 $3200 for complete engine. + Shipping 4mil 466cc Small-Block Twister Bead-Blasted matching halves stock cases bored and port-matched to the twister cylinders 4mil hotrods crank trued and welded max-load bearings on both ends of crank 71.5mm bore Small-Block Twister Cylinders Aggressive dune port from Kevin @ HJR Wiseco 423 series pistons with about 15hrs on them 25cc domes (175lbs compression at sea level, and 130lbs compression at 7200ft elevation) Vforce3 Reeds Billet Intakes 33-35mm Adjustable timing plate lightened flywheel straight-cut gears magnum billet basket direct drive lockup & cover billet impeller billet water pump cover pancake bearing shift-star mod side-cut gears shift-shaft mod billet stator cover This engine will make right around the 100hp mark on methanol. I am selling this for my buddy Overdose. It runs good, no problems. He wants to build a 10mil. I built this engine back in october. Everything on it is nicely polished now. Feel free to PM me with any questions. $400 for the carbs + shipping Keihin 33 PWK's set up for methanol by me. Chariot Billet Bowls (the big ones) .118 dumps & mains EGL Needles Clippard Power-Jets with K&T cut powerjet needles 68 pilots Uni POD Filters & outerwears gravity-feed Quote Link to comment Share on other sites More sharing options...
MarineNYC Posted May 31, 2012 Report Share Posted May 31, 2012 Sweet motor man Quote Link to comment Share on other sites More sharing options...
moneybags Posted May 31, 2012 Report Share Posted May 31, 2012 How far or big can those cylinders be bored out? Those cylinders have crazy thick cylinder walls. Quote Link to comment Share on other sites More sharing options...
Overdose Posted May 31, 2012 Report Share Posted May 31, 2012 If I remember right those will bore out to right at 76mm max Quote Link to comment Share on other sites More sharing options...
BigRed350x Posted May 31, 2012 Author Report Share Posted May 31, 2012 If I remember right those will bore out to right at 76mm max Matt is correct, these particular sleeves can go to 76mm. There is a TON of life left in them. This is a great deal for an awesome dune motor. This thing runs awesome. Quote Link to comment Share on other sites More sharing options...
BigRed350x Posted June 1, 2012 Author Report Share Posted June 1, 2012 Bumpity Quote Link to comment Share on other sites More sharing options...
Overdose Posted June 1, 2012 Report Share Posted June 1, 2012 Bump for a sweet engine. Quote Link to comment Share on other sites More sharing options...
ban565 Posted June 2, 2012 Report Share Posted June 2, 2012 Sweet motor Bigred. This motor is worth the cost. I do like twister motors. Quote Link to comment Share on other sites More sharing options...
Nieskes Posted June 2, 2012 Report Share Posted June 2, 2012 Overdose, you have any interest in selling the top end? Quote Link to comment Share on other sites More sharing options...
BigRed350x Posted June 2, 2012 Author Report Share Posted June 2, 2012 Overdose, you have any interest in selling the top end? I don't think he wants to part it out right now. Trying to sell as a whole. - Jared Quote Link to comment Share on other sites More sharing options...
Trick2stroke Posted June 3, 2012 Report Share Posted June 3, 2012 That's one beefy motor. Love the billet cylinders. Quote Link to comment Share on other sites More sharing options...
JpRedline Posted June 4, 2012 Report Share Posted June 4, 2012 Free bump,Sick engine! If part out, Dibs on the bottom end! Quote Link to comment Share on other sites More sharing options...
Nieskes Posted June 4, 2012 Report Share Posted June 4, 2012 And I still want the top end!!!! Quote Link to comment Share on other sites More sharing options...
Overdose Posted June 5, 2012 Report Share Posted June 5, 2012 And I still want the top end!!!! motor is still available has a whole unit. i will only part it out if all parts are spoken for in advance. Thanks Quote Link to comment Share on other sites More sharing options...
Overdose Posted June 11, 2012 Report Share Posted June 11, 2012 Dropping the price to $2800+shipping obo. Someone is gonna get a great deal here. PM me or BigRed Quote Link to comment Share on other sites More sharing options...
