what carb size for my dune/play port?
My buddy runs 33pwks. Good all around carb.. I run 28's
He does a lot more drag racing on his bike... I do 99% trails. His trail bike also runs 28's
Edited by zach45
ive ran stock carbs, 28mm, and 34mm carbs. what size carb would be best for 60%trails, 30% Draging in fields and 10% road riding? The 28mm's werent enough, but the 34mm's were a bit to much.
opinions on what size carbs i need?
what do you mean they were a bit too much? hows the low end on 34's compared to stock? curious cuz i have a dune ported 4 mil. i know the bigger the carb the more top end.
get 35 pwk .. i run airstrikers your choice but go 35s you will thank me later... my bike has a dune port bottom end seems the same as stock carbs :confused: ... but the mid and top end rips! pulls forever, doesn't run out of fuel like the stockers! :headbang: .. :bolt:
I would put some serious thought into a 2:1 setup with a 35PWK 38 Would probably be a bit much. I swear by mine and I know a few trail/all type riders who also wouldnt switch back..
If You say the 28s arent putting out enough I know The 2-1 setup would give you more power everywhere. For Sure.
What Pipes and other mods do you have to up the power/compression on your SHEE?
