long travel shock choice
KAMIKAZE
time to buy some long travel shocks to suit my alba +2 arms
tossing up between
Elka stage2+R
* Preload
* Rebound
* External Reservoir
* 36mm body, 16mm shaft
Works Pro Series Piggyback TRS
2-way adjustable damping
Triple-Rate Springs
Eighteen-position compression adjustments
5/8-inch diameter shafts
exteral reservoir
thought i would add pics
bike is a dune/play bike
what would you choose ?
I do not have long travel.. Nor have I had Elka on my bike... But I have works g series on my weekend warrior, and I love them. more then good enuf for me. Shit load cheaper too..
Yeah I have the alba long travel arms
My stock shocks are completly fucked so time to replace them
These 2 brands above are equally priced
Just wasn't sure if one was better/worse then the other
Or any options for the $1000aud mark
Bike doesn't get used enough to justify huge $$ on shocks
hands down. buy motowoz if you got the penny. Thats what i use on my xc ltr 450, and my banshee as well. i
I have the long travel Alba's as well. I recommend Fox Float Evols hands down they are top notch shocks and extremely versatile. I will say there equal to a set of Axis shocks but better than Elka's. You will need a 17" shock eye to eye in order for it to properly be setup. Here is a picture of mine already setup. On a side note I will be selling these shocks for $650 shipped if you interested.
Buy those floats before someone else does. Those are the best choice of all that were mentioned, and priced right! You can can them rebuilt for 125 if they need it and for another 100 bucks you can upgrade to the Kashima coating. I have 20.5" long travel floats on my R and they are by far the best shocks I've ever owned. I finally took the time this spring to properly set them up and they are second to none.
PM returned
Yes the floats are little more expensive than the works shocks but about the same price range as Elka Stage 4's which not to many people have. For the rear shock I would just have your stocker revalved for your weight and riding style.
pm sent re fox shocks
arnt the fox floats/axis a fair bit more expensive then the elka/works shocks ?
do you guys get the matching rear?
or just revalve ect
thanks for the help
