left side runs like crap
so i split the cases and did upgrades and after i put everything back together i did a leak down test 6 for 6 and it passed . sync carbs with sync tool and dead on . now the left side even after i shot off the engine and pull a carb off or pull out a plug there is white well what seems to be white smoke omes out of cyl. and ive put on the noss head prolly about 6 times to stop that one side from leaking thinking its the head and i put new rings in and use white grease with the o-rings . any idea what it is should i split the cases again . doesnt seem to be looseing tranny oil and i put new seals and crank bearings in . any ideas would help thanks
