Dave G Posted May 25, 2012 Report Share Posted May 25, 2012 Hey guys....quick question. I have stock headlights on my Shee....and they are pretty dim. Anyone know if I can replace them with H1 or H3 (55w) bulbs without burning up the stator or regulator? Has anyone done this already? Thanks again! Quote Link to comment Share on other sites More sharing options...
So Cal Suspension Posted May 25, 2012 Report Share Posted May 25, 2012 zilla (for once) is right. a 55w bulb will actually be dimmer than a 35w bulb. The stock stator puts out roughly 75-77 watts total on the lighting circuit. Stock replacement bulbs are h6m, btw Quote Link to comment Share on other sites More sharing options...
Chip M Posted May 25, 2012 Report Share Posted May 25, 2012 use 35 watt, 55 watt is too much for a stock stator to handle. also the banshee is H6M bulbs something like this would work http://www.ebay.com/...r#ht_627wt_1163 Thanks for the link!!. Helps me out too Quote Link to comment Share on other sites More sharing options...
Dave G Posted May 26, 2012 Author Report Share Posted May 26, 2012 Awesome! Thanks guys!!!! Quote Link to comment Share on other sites More sharing options...
Wassup350 Posted June 10, 2012 Report Share Posted June 10, 2012 I just put some 35w bulbs on and they are dim unless y ou run only one bulb. The box says 75w on it as well so I'm thinking that may be to much. I'm wondering if it has something to do with I have a 87 and the bulbs are for a newer machine. Below is the link to the bulbs I got URL: http://pages.ebay.com/link/?nav=item.view&id=270954377814 Quote Link to comment Share on other sites More sharing options...
bansheesandrider Posted June 10, 2012 Report Share Posted June 10, 2012 I just put some 35w bulbs on and they are dim unless y ou run only one bulb. The box says 75w on it as well so I'm thinking that may be to much. I'm wondering if it has something to do with I have a 87 and the bulbs are for a newer machine. Below is the link to the bulbs I got URL: http://pages.ebay.com/link/?nav=item.view&id=270954377814 ALL Banshees take the same light bulbs in the headlights! All years have the same output stators stock. You should be able to run 2 35 watt bulbs no problem, if the box says 75w on it then I think you have 2 75 watt bulbs, not 2 35 watt bulbs. Quote Link to comment Share on other sites More sharing options...
Wassup350 Posted June 13, 2012 Report Share Posted June 13, 2012 On the Ebay add it stated that they were 35W but on the packaging it says 35/35W up 75/75w, the bulb it self just says 12v 35/35w so I'm a little confused Quote Link to comment Share on other sites More sharing options...
guns4children Posted June 13, 2012 Report Share Posted June 13, 2012 Go to rmatv and get the tusk bulbs. They are 10 bucks a piece and well worth it. Quote Link to comment Share on other sites More sharing options...
So Cal Suspension Posted June 13, 2012 Report Share Posted June 13, 2012 On the Ebay add it stated that they were 35W but on the packaging it says 35/35W up 75/75w, the bulb it self just says 12v 35/35w so I'm a little confused The 75w rating is the comparable halogen light output. Meaning, it's a 35w xenon bulb equivalent to a 75w halogen bulb. It only draws 35w. You got the right ones. Quote Link to comment Share on other sites More sharing options...
DirtDiggler69 Posted June 14, 2012 Report Share Posted June 14, 2012 Do you have the switch set to low beam or high beam? Quote Link to comment Share on other sites More sharing options...
sheerider1026 Posted June 14, 2012 Report Share Posted June 14, 2012 Is it the stator that supplies the voltage for lighs??? Quote Link to comment Share on other sites More sharing options...
MyNameIsMud Posted June 14, 2012 Report Share Posted June 14, 2012 I tried the walmart lights on mine since i didnt have any at all.I got the idea here and its pretty bright.I plan to run them until i can afford mattscss's lights. Quote Link to comment Share on other sites More sharing options...
