eXemP Posted May 25, 2012 Report Share Posted May 25, 2012 Carbs are tuned but the right cylinder is smoking alot, any ideas? Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted May 25, 2012 Report Share Posted May 25, 2012 Crank seal. How do you know your carbs are tuned? Quote Link to comment Share on other sites More sharing options...
eXemP Posted May 25, 2012 Author Report Share Posted May 25, 2012 crank seals are new, could it be the needle jet? Quote Link to comment Share on other sites More sharing options...
Gog Posted May 25, 2012 Report Share Posted May 25, 2012 Could have a bad seal in your coolhead.does it smoke even after it's turned off? Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted May 25, 2012 Report Share Posted May 25, 2012 Could have a bad seal in your coolhead.does it smoke even after it's turned off? True. You should be able to smell that right away to. Quote Link to comment Share on other sites More sharing options...
jack2012 Posted May 25, 2012 Report Share Posted May 25, 2012 No smoke when turned off. Could have a bad seal in your coolhead.does it smoke even after it's turned off? Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted May 25, 2012 Report Share Posted May 25, 2012 How do you know the carbs are synced? Quote Link to comment Share on other sites More sharing options...
possum Posted May 25, 2012 Report Share Posted May 25, 2012 Check coil. Might be loose wires. Same thing happened to me Quote Link to comment Share on other sites More sharing options...
eXemP Posted May 25, 2012 Author Report Share Posted May 25, 2012 http://www.youtube.com/watch?v=IuQuc8J7ij8 Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted May 26, 2012 Report Share Posted May 26, 2012 Okay, like I said, how do you know the carbs are synched? Just cause your crank seals are new doesn't mean they can't leak. And you say there new, so you had the cases split. Did you seal them up good enough? Quote Link to comment Share on other sites More sharing options...
jack2012 Posted May 26, 2012 Report Share Posted May 26, 2012 Theres the you tube link you can see the build. I synced the carbs with a hose oil tool And leveled them out. Could it be a needle jet or main? Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted May 26, 2012 Report Share Posted May 26, 2012 How do the plugs look? That's a lot of smoke. The smoke never clears. So unless your running different jets in each carb, I think you're burning something else. Quote Link to comment Share on other sites More sharing options...
maskmanLS6 Posted May 26, 2012 Report Share Posted May 26, 2012 Looks like oil or tranny smoke, If it were your pre mix i would think it would clear up some once under a load and warm. Keep your eye on the tranny fluid level cause i think your burning more than gas on that side. Having one side jetted might cause it too but thats alot of smoke for even jetting to cause. Quote Link to comment Share on other sites More sharing options...
jewels Posted May 26, 2012 Report Share Posted May 26, 2012 def check those plugs.. that's a lot of smoke for sure. it has to be a prob in that carb or the cylinder head... check compression in both see if there is a differance.. look for the simple things first ... good luck! Quote Link to comment Share on other sites More sharing options...
jack2012 Posted May 26, 2012 Report Share Posted May 26, 2012 Looks like you were right. tranny fluid was a half low, so i took the cover off and fond the crank oil seal was bad. i have another one. is there a way to change it without splitting the cases? Looks like oil or tranny smoke, If it were your pre mix i would think it would clear up some once under a load and warm. Keep your eye on the tranny fluid level cause i think your burning more than gas on that side. Having one side jetted might cause it too but thats alot of smoke for even jetting to cause. Quote Link to comment Share on other sites More sharing options...
