high idle
guys when i start my she it has a very high idle for bout a min or better then it idle down to normal idle. Any help on what could be the problem? It only does it the very first start or the day. carbs are 34pjs 160mains 50pilot
Check to see that your throttle cable isn't bound up at all and then when you start it it vibrates back to the position it needs to be, wouldnt hurt to lube it up with some wd-40. That or you may have a small air leak. Check your crossover tube and carb boots for any cracks.
Sent using Tapatalk!
