Right carb spews gas when the gas is on
I'm wrapping up my build and when I was getting ready to start her up I noticed my right carb is overflowing when the gas is on. I set the float height on both carbs last night, but only the right side is leaking. Any suggestions besides check for a stick float and check float height?
I would check for a hung up float
Hit it with the screw driver then picked the ass end up a few times and slammed it down. Now more overflow! Any idea why it happened? Should I take it apart and clean it? (again)
just was stuck mine doesnt it every now and then after rejetting or tearin them apart doesnt usually happen again till i mess with them again
I got the same issue too, right side carb also. I diagnosed it to be the needle assembly, mainly the needle had nicks on it from something and was catching up on the inside of whatever the fuel inlet thing is called. I took the carb off and moved the float up and down and like 30% chance it would get stuck, and I mean stuck, I had to use pliers to get the needle out, I've never seen it like that but I smoothed out the 3 sides of the needle and helped but I ended up getting new carb gets for like $15 each so it has new needles and everything so I don't have to worry about it when I'm out riding. Going to pick up the kits today so havent put em in yet but I know that was the problem....
