Timing key mod
The VITOS advanced timing key is like $25.. It won't kill your wallet. And if it does, look at the DIY timing plate mod thread. It is in the tech section.
Is there a way to make your own timing key. If so please answer.
Using the key is a POOR way of changing your timing. You are far better off either modifying the stock timing plate or buying an aftermarket plate that will let you change your timing in a manner that you know how much you changed it.
