Sandworks Posted May 20, 2012 Report Share Posted May 20, 2012 just rebuilt bike, took it out ran fine for 30 min, did some draging. then the right side was only hitting at high RPM. so i put new plugs in, NOPE. then i switch plug wires, NOPE. then i switched carbs, NOPE. now i got it home and good comp and cylinder looks good. starting to pull my hair out!! lol. and ideas? vac leak?? if the crank was out of true would that do it? thanks Quote Link to comment Share on other sites More sharing options...
Jereme6655 Posted May 21, 2012 Report Share Posted May 21, 2012 How about the choke tube? Quote Link to comment Share on other sites More sharing options...
Sandworks Posted May 21, 2012 Author Report Share Posted May 21, 2012 No choke tube, have 34pj's and vforce 3 reeds with spacers. Got to b a vac leak! Quote Link to comment Share on other sites More sharing options...
Sandworks Posted May 21, 2012 Author Report Share Posted May 21, 2012 come on guys! could the stator cause the prob? even tho i switched plug wires and its still on the same side Quote Link to comment Share on other sites More sharing options...
Sandworks Posted May 21, 2012 Author Report Share Posted May 21, 2012 come on guys! could the stator cause the prob? even tho i switched plug wires and its still on the same side The stator cheak was good but the coil not so good, look at more later Quote Link to comment Share on other sites More sharing options...
Sandworks Posted May 22, 2012 Author Report Share Posted May 22, 2012 Boy you guys are a lot of help, thanks Quote Link to comment Share on other sites More sharing options...
thomas h. Posted May 22, 2012 Report Share Posted May 22, 2012 I don't have your carbs but float hight was my issue. Quote Link to comment Share on other sites More sharing options...
