turbowrenchhead Posted May 18, 2012 Report Share Posted May 18, 2012 (edited) So day three owning my first banshee. I pulled the drain plug and dropped the oil and its creamy white colored. So its either a jug gasket or a jug right? After its all fixed the $900 purchase price is going to be small compared to the fixes. Edited May 18, 2012 by turbowrenchhead Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted May 18, 2012 Report Share Posted May 18, 2012 Or the water pump seal,or the o ring that goes there to the clutch cover. Quote Link to comment Share on other sites More sharing options...
Finch Posted May 18, 2012 Report Share Posted May 18, 2012 my money is on the seal or just old oil Quote Link to comment Share on other sites More sharing options...
Josh Z Posted May 19, 2012 Report Share Posted May 19, 2012 water in there... change it. run it for a min, then flush it like 2-3 times... if it is still milky you have a leak Quote Link to comment Share on other sites More sharing options...
turbowrenchhead Posted May 19, 2012 Author Report Share Posted May 19, 2012 I'm tempted to pull the motor and replace all the gaskets and reseal the cases. Port my cylinders while I'm at it. Quote Link to comment Share on other sites More sharing options...
turbowrenchhead Posted May 19, 2012 Author Report Share Posted May 19, 2012 Whats the quart capacity? Quote Link to comment Share on other sites More sharing options...
maskmanLS6 Posted May 19, 2012 Report Share Posted May 19, 2012 Whats the quart capacity? Quart capacity is 1.5 and you dont screw the stick down to check the level. your problem is probably the o ring on the coolant tube that goes through the clutch cover from the water pump. Quote Link to comment Share on other sites More sharing options...
Zwiser Posted May 19, 2012 Report Share Posted May 19, 2012 Im betting on the water pump seal... while your in there put a billet impeller and a pancake bearing. Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted May 19, 2012 Report Share Posted May 19, 2012 I'd run and flush with cheep ATF. If it's still real milky after 2nd try, do the pump seal and tube O-ring. I'd save the port job until winter, it's time to ride NOW !! Quote Link to comment Share on other sites More sharing options...
turbowrenchhead Posted May 19, 2012 Author Report Share Posted May 19, 2012 Im betting on the water pump seal... while your in there put a billet impeller and a pancake bearing. Have a link handy for the billet impeller and bearing? Quote Link to comment Share on other sites More sharing options...
turbowrenchhead Posted May 19, 2012 Author Report Share Posted May 19, 2012 I'd run and flush with cheep ATF. If it's still real milky after 2nd try, do the pump seal and tube O-ring. I'd save the port job until winter, it's time to ride NOW !! I know! lol. I have two atv trips coming up. This memorial day weekend, but thats for the whole family which is going to be a very slow paced one. My 7 year old son likes to put at 5mph. So the shee won't be a good machine to take. However I have a all guys trip on June 14th that I would like to take it with for. There's going to be another shee there. A 250R Honda atc. Possibly a raptor 660, a yfz 450. So yeah I want to be able to compete. Quote Link to comment Share on other sites More sharing options...
tedd1 Posted May 19, 2012 Report Share Posted May 19, 2012 Farm And Sand Toys 1 (785) 364-5325 Will fix you right up!! Quote Link to comment Share on other sites More sharing options...
turbowrenchhead Posted May 19, 2012 Author Report Share Posted May 19, 2012 Thanks for the assist. I will call that number on Monday. I ordered new gaskets and seals for the waterpump from the dealer for now. Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted May 19, 2012 Report Share Posted May 19, 2012 Get the O-ring that goes on coolant tube from pump to head Quote Link to comment Share on other sites More sharing options...
turbowrenchhead Posted May 19, 2012 Author Report Share Posted May 19, 2012 Get the O-ring that goes on coolant tube from pump to head I did. I ordered the pump gasket, pump seal and two coolant line o rings Quote Link to comment Share on other sites More sharing options...
