runs good only with choke on
I have a 2004 banshee, i ran great for a couple years and when I got it out this summer it had issues. it will not ide and dies and back firers. It runs fine with the choke on. we took the carbs apart and clean everything checked the choke and choke tube
Not sure what it can be
by "cleaned the carbs" did you mean you took both pilot and main out and visually inspected them to make sure they were clear? sitting usually clogs the jets and by using the choke you are adding fuel that the jets cant supply. backfiring can also in tale stuck rings from sitting. or lack of combustion. seen a lot of bikes hang rings after sitting a long time.
If you changed nothing you don't need bigger jets, yoe need cleaner carbs. A quick douche with carb spray isn't cleaning them. I would suggest a can of http://www.berrymanproducts.com//Portals/0/images/0996.jpg. Make sure you pull the pilot jet. Do not soak any plastic or rubber. :cheers:
FAIL banghead try this http://berrymanproducts.com/Products/PartCleanersandDegreasers.aspx carb dip
Edited by Larry's Shee
We had carbs a part pilot and mains removed, cleaned the hell out of everything. Was thinking maybe go all out replace reeds floats, jet it with new pipes etc
You have to remove pilots also. I still think you need to soak the carbs. Just like rotten pussy, sometimes a quick douche don't fix it banghead . From the sounds of it, until you can make a stocker run, you don't need to start modding :rolleyes:
Did you make sure the pilot was clean? I had the same problem and it turned the pilot jets were plugged.
There are little holes on the side of jet that need to be open also :whoa:
