turbowrenchhead Posted May 18, 2012 Report Share Posted May 18, 2012 Is there an aftermarket piece available that I can bolt up to the case that will fix this issue? Is a case saver the same thing? Quote Link to comment Share on other sites More sharing options...
blubyyou Posted May 18, 2012 Report Share Posted May 18, 2012 I run a T.M. Design case saver. It's plastic and has some give if the chain were to break. It fits over the shaft the sprocket goes on and is quite beefy. Well work the money I think. I personally like it much better than the metal ones. Quote Link to comment Share on other sites More sharing options...
blubyyou Posted May 18, 2012 Report Share Posted May 18, 2012 If you need the case repaired find a shop that TIG welds and they should be able to repair it for you. Then install a case saver to keep it from happening again. Quote Link to comment Share on other sites More sharing options...
VoOK Posted May 18, 2012 Report Share Posted May 18, 2012 I run a T.M. Design case saver. It's plastic and has some give if the chain were to break. It fits over the shaft the sprocket goes on and is quite beefy. Well work the money I think. I personally like it much better than the metal ones. x2 Quote Link to comment Share on other sites More sharing options...
