Tedder Posted May 17, 2012 Report Posted May 17, 2012 i seen some of this stuff in the parts store,but wasnt sure it would work guess i will try that and some stronger springs oh and i only feel it when i launch really hard in first gear I wasn't recommending it as a fix for what you've got going on. You're problem is that the settings are way off and adding five bottles of the stuff won't fix that. What I ment was that once your setup correctly you may occasionally have days when a little chatter develops. If your between rounds and don't have time or don't want to make clutch changes that may screw up your dial you can add a (little) of the additive to help calm it down. Quote
SlowerThanYou Posted May 18, 2012 Report Posted May 18, 2012 I wasn't recommending it as a fix for what you've got going on. You're problem is that the settings are way off and adding five bottles of the stuff won't fix that. What I ment was that once your setup correctly you may occasionally have days when a little chatter develops. If your between rounds and don't have time or don't want to make clutch changes that may screw up your dial you can add a (little) of the additive to help calm it down. I wish I could be as nice as you. This guy is a total idiot. He had this problem a year ago, you & I gave him the proper advice. He runs 1.17 & 1.18 60's so I'm sure he knows what he's doing, LOL! Apparently not, he's still breaking them a year later. Quote
stroking Posted May 19, 2012 Author Report Posted May 19, 2012 I wasn't recommending it as a fix for what you've got going on. You're problem is that the settings are way off and adding five bottles of the stuff won't fix that. What I ment was that once your setup correctly you may occasionally have days when a little chatter develops. If your between rounds and don't have time or don't want to make clutch changes that may screw up your dial you can add a (little) of the additive to help calm it down. ok got it thanks Quote
