stroking Posted May 15, 2012 Report Posted May 15, 2012 Clutchs keep breaking.....only the ones closest to the motor,the ones close to pressure plate does not do this....has happen with 3 different type of clutches billet basket...steel plates still look new Quote
BigRed350x Posted May 15, 2012 Report Posted May 15, 2012 Out of balance? Got any grooves in your basket? Usually the fibers breaking like that is caused by uneven distribution of pressure on the clutch plate fingers.... Quote
Wheelman Chassis Posted May 15, 2012 Report Posted May 15, 2012 Clutchs keep breaking.....only the ones closest to the motor,the ones close to pressure plate does not do this....has happen with 3 different type of clutches billet basket...steel plates still look new Are you running asphalt? this always happend to me when i first started clutch tuning.. its mostly caused by tire shake or a spin then hard hook condition. the fix or one of them is in one of my post in the lock out tuning thread.. if you cant find it pm me.. Chris WheelmanChassis Quote
sheerider11 Posted May 15, 2012 Report Posted May 15, 2012 Warped pressure plate, warped hub, or grooved basket. Quote
Wheelman Chassis Posted May 15, 2012 Report Posted May 15, 2012 you sure your pressure plate isn't warped? maybe over tightening of the pressure plate as well. had this happen on my old zilla, i had over tighten the plate, broke the first two fibers. please explain how a warped plate or a grooved basket cause proken fibers? Quote
Wheelman Chassis Posted May 15, 2012 Report Posted May 15, 2012 a warped plate can cause uneven pressure on the fiber causing them to flex. lol that would have to be a hel of a warp..lol Quote
Tedder Posted May 15, 2012 Report Posted May 15, 2012 Want some broken steels to accompany those fibers? lol... Been there done that. We run asphalt - It's caused by clutch chatter You can usually feel what seems like the chain jumping the rear sprocket. Quote
Wheelman Chassis Posted May 15, 2012 Report Posted May 15, 2012 Want some broken steels to accompany those fibers? lol... Been there done that. We run asphalt - It's caused by clutch chatter You can usually feel what seems like the chain jumping the rear sprocket. that my opinion also.. glad im not crazy....lol chris Quote
alcoholbanshee Posted May 15, 2012 Report Posted May 15, 2012 Agreed with Chris and Tedder............Been there done that Quote
stroking Posted May 16, 2012 Author Report Posted May 16, 2012 yes its asphalt only and it did feel like the chain was jumping on the sprocket how do i fix this ? tired of breaking good clutches Quote
Tedder Posted May 16, 2012 Report Posted May 16, 2012 There are a number of factors (sometimes a combination) that can cause chatter. When do you feel it? Mine was most violent at the 1-2 shift. Some days I can still get a little shutter depending on track condition/launch & shift RPM etc. Running on asphalt I assume you use a lockup? Do you use cork based fibers? Without getting into a big drawn out post my best advice would be to increase both primary spring pressure and lockup arm weight to stop the chatter then work back to find the combination that works for your setup. If you want to try one change I'd add primary pressure first..... *Once you get a handle on it and only in a pinch - If you have a little suprise chatter develop out of the blue a splash of GM limited slip additive can help tame it. Quote
SlowerThanYou Posted May 16, 2012 Report Posted May 16, 2012 Clutchs keep breaking.....only the ones closest to the motor,the ones close to pressure plate does not do this....has happen with 3 different type of clutches billet basket...steel plates still look new Seems like you keep bringing this old topic up. You asked it a while ago on another site. You didn't like the answers you got from Tedder & I. Your clutch tune-up is not happy. There are many fixes to the chatter, but you don't want to listen. You don't need to ask anyone anything. According to your times you were running in the past. You have the worlds fastest Banshee running low 5's & with sub 1.20 60's. You need to be sharing some of your clutch secrets with us. Quote
stroking Posted May 17, 2012 Author Report Posted May 17, 2012 a splash of GM limited slip additive can help tame it. i seen some of this stuff in the parts store,but wasnt sure it would work guess i will try that and some stronger springs oh and i only feel it when i launch really hard in first gear Quote
