Tf705 Posted May 15, 2012 Report Share Posted May 15, 2012 I installed a dunable override last year. It never shifted very easily. I have the motor apart right now replacing the crank. What should I look at or look for while it's apart? I want to fix this. I here everybody say that there's shifts like butter. I want that. Any help would be appreciated. Quote Link to comment Share on other sites More sharing options...
Surfrjag Posted May 15, 2012 Report Share Posted May 15, 2012 Did you get it new? Usually the forks get bent from backloading. Quote Link to comment Share on other sites More sharing options...
BigRed350x Posted May 15, 2012 Report Share Posted May 15, 2012 Make sure your back-cut gears are cut at a 45deg angle. An incorrect angle will make them shift like crap. Post up pics of your forks when you get it apart. Quote Link to comment Share on other sites More sharing options...
Tf705 Posted May 15, 2012 Author Report Share Posted May 15, 2012 i sent them my stock trans and they cut it. the shift forks are fine, there not bent at all. also im not a trans pro so what do you mean my back cut gears? Quote Link to comment Share on other sites More sharing options...
04_blu_shee Posted May 16, 2012 Report Share Posted May 16, 2012 Who did you get to build your dunable override...I have a WCR ran it part of a day and no 4th. Tore it down and one of the gears shelled. Sent it back now it shift ok some of the time. Good luck till you go full override my .02 Quote Link to comment Share on other sites More sharing options...
