Wassup350 Posted May 14, 2012 Report Share Posted May 14, 2012 Okay I have a single 35mm kehin pwk. This thing smokes a lot! runs very rich. I currently have a 178 main, 2nd clip down on a dek needle, and a 35 pilot jet! It has an open air box, with dmc pipes with the 2 into one silencer. Adlai has boyeson dual stage power reeds. The thing won't idle, and fouls plugs, the mid rage and top end RPMs run fairly well but it's the lower RPMs that run very rich. I also can't get anything lower than a 35 pilot from the dealer. it also has a boyeson float bowl. Quote Link to comment Share on other sites More sharing options...
zach45 Posted May 14, 2012 Report Share Posted May 14, 2012 (edited) Explain to us "rich" because no banshee should need. 35 pilot. Sent from my iPhone using Tapatalk Edited May 14, 2012 by zach45 Quote Link to comment Share on other sites More sharing options...
Wassup350 Posted May 14, 2012 Author Report Share Posted May 14, 2012 This is why I'm stumped, its running very rich, smokes a lot and the plug is wet when I pull it. Quote Link to comment Share on other sites More sharing options...
sheerider1026 Posted May 14, 2012 Report Share Posted May 14, 2012 Is the choke on? Quote Link to comment Share on other sites More sharing options...
Wassup350 Posted May 14, 2012 Author Report Share Posted May 14, 2012 The spark is nice and blue and I completely went through and redone the wiring harness, also once it revs up it seems to run better. Quote Link to comment Share on other sites More sharing options...
roy581 Posted May 14, 2012 Report Share Posted May 14, 2012 If your running a two into one carb and a two into one exaust it wont work right their has been a few people With the same problem.I have the two into carb with t5 pipes and mine runs excellent Dek needle middle clip 52 pilot 190 main fuel/air screw 11/4 turns out. This jetting is perfect on my bike as i had it dyno jetted. Quote Link to comment Share on other sites More sharing options...
Wassup350 Posted May 14, 2012 Author Report Share Posted May 14, 2012 Will that's interesting, I use to have a banshee with the dynoport 2 into 1 pipe and that ran awesome. Quote Link to comment Share on other sites More sharing options...
roy581 Posted May 14, 2012 Report Share Posted May 14, 2012 I didnt realize it was dual chambered system sorry! But if you google the two into one system their Has been alot of problems running both two into systems. Anyway my mistake Quote Link to comment Share on other sites More sharing options...
roy581 Posted May 14, 2012 Report Share Posted May 14, 2012 All right well good luck someone on hear will figure it out as theirs alot of people on Hear that will help. Quote Link to comment Share on other sites More sharing options...
WINDYCITYJOHN400 Posted May 14, 2012 Report Share Posted May 14, 2012 Is the slide bottoming out when your off the throttle? Or is the idle screw holding it up some? Are your floats set correctly? With no porting or major mods, you might need a smaller main. I know the main isn't part of the low end jetting...but if it's FAT on the top end....it's just getting wet in the cases and might take a lot to lean it down at idle. Timing? Quote Link to comment Share on other sites More sharing options...
Wassup350 Posted May 14, 2012 Author Report Share Posted May 14, 2012 Timing should be stock, I orderered a new idle screw, I think that the one on it its messed up (plastic). I well check the floats tonight, didn't think that they were off because it doesn't leak GAs at all. Quote Link to comment Share on other sites More sharing options...
WINDYCITYJOHN400 Posted May 14, 2012 Report Share Posted May 14, 2012 Timing should be stock, I orderered a new idle screw, I think that the one on it its messed up (plastic). I well check the floats tonight, didn't think that they were off because it doesn't leak GAs at all. If the fuel is higher than designed to be....the fuel will pull into and thru the jets too easy, making the carb flow more fuel than it would if the fuel was lower in the bowls. (Like drinking that last sip from your coke with a straw takes more effort and time than the first.) Quote Link to comment Share on other sites More sharing options...
Wassup350 Posted May 15, 2012 Author Report Share Posted May 15, 2012 Thanks for the replies, I'm down to a 165 main. Once I get my shocks redone I'll burn off that excess fuel. I'm fairly certain I have it figured out. I also put a 45 pilot in it. Hopefully that will do the trick. Quote Link to comment Share on other sites More sharing options...
ticktock Posted May 15, 2012 Report Share Posted May 15, 2012 My 2-1 was 58/170 EEK needle, one of the problems I found between two bikes, one being a friends, was that I had an airbox and this caused the bike to be Rich. you might want to try switching to a pod, I sold my buddy my airbox adapter and with the same jetting on his that ran perfect it was fucking up and too rich. Food for thought. Adam Quote Link to comment Share on other sites More sharing options...
mk2dubbin Posted May 16, 2012 Report Share Posted May 16, 2012 03DMshee and I both have identical setups and are running 52 pilot with 175 main. stock motors, no porting, both on 916 pipes. another friend has pro circuit pipes and is running 48 pilot and 170 main. 800-1200 elevation here in PA. Quote Link to comment Share on other sites More sharing options...
