bball23 Posted May 14, 2012 Report Share Posted May 14, 2012 Hey all I just rebuilt my carbs yesterday because they were leaking from overflow and theres no leak but it wont start now. I rebuild the topend 3 weeks ago and it was running mint and jetted perfect. Now when I put them back on the quad today it started up and idled for a couple mins and then shut off. I tried kicking it again and got nothing. Im pretty sure I did everything right and am stumped on what the problem is... The choke tube is there and everything looks good. Any help would be greatly appreciated. If I get nothing ill just try to put it back together with the old parts and see if that will work... Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted May 14, 2012 Report Share Posted May 14, 2012 Hey all I just rebuilt my carbs yesterday because they were leaking from overflow and theres no leak but it wont start now. I rebuild the topend 3 weeks ago and it was running mint and jetted perfect. Now when I put them back on the quad today it started up and idled for a couple mins and then shut off. I tried kicking it again and got nothing. Im pretty sure I did everything right and am stumped on what the problem is... choke tube is there and everything looks good. Any help would be greatly appreciated. If I get nothing ill just try to put it back together with the old parts and see if that will work... gas?? Quote Link to comment Share on other sites More sharing options...
bball23 Posted May 14, 2012 Author Report Share Posted May 14, 2012 yes it has gas. Everything looks good just dont know why it wont start... Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted May 14, 2012 Report Share Posted May 14, 2012 check for loose or bare wire. Have you checked for spark? Quote Link to comment Share on other sites More sharing options...
bball23 Posted May 14, 2012 Author Report Share Posted May 14, 2012 yes I checked the plugs and there is spark in both. It has to be the the carbs since it was perfect and started first kick before i rebuilt them... Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted May 14, 2012 Report Share Posted May 14, 2012 Was thinking a wire might have got bumped then finished off when running. Try rapping float bowls with screwdriver handle, they might just be hung up. Check fuel flow from petcock Quote Link to comment Share on other sites More sharing options...
bball23 Posted May 14, 2012 Author Report Share Posted May 14, 2012 Was thinking a wire might have got bumped then finished off when running. Try rapping float bowls with screwdriver handle, they might just be hung up. Check fuel flow from petcock Ill try that tomorrow and will let you know. It might be hung up because it has new plungers so they might be stuck... Quote Link to comment Share on other sites More sharing options...
yzrmbsg Posted May 14, 2012 Report Share Posted May 14, 2012 It sounds like you let it idle.... And while idling, you fouled your plugs. Swap em out for new ones and see what happens. Could just be flooded and you need to let it sit for a bit and evaporate. If that doesnt work, check the simple stuff, both key and kill switch on? Gas in it and on? Choke stuck on/off? Pull the carbs back off and make sure you put them back together correctly. Good luck! Sent using Tapatalk! Quote Link to comment Share on other sites More sharing options...
banshee760 Posted May 14, 2012 Report Share Posted May 14, 2012 Ur bike is floooded. Keep on kicking it will start and idle for a litle bit then shut of even if u give it gas continue to do so in till u unflooded Quote Link to comment Share on other sites More sharing options...
banshee760 Posted May 14, 2012 Report Share Posted May 14, 2012 Also take the exes gas of the plugs theyr probly wet or fouled but ur bike is flooded Quote Link to comment Share on other sites More sharing options...
bball23 Posted May 14, 2012 Author Report Share Posted May 14, 2012 Also take the exes gas of the plugs theyr probly wet or fouled but ur bike is flooded the plugs arent really too wet though and i did take apart the carbs again and put them back in... Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted May 14, 2012 Report Share Posted May 14, 2012 Pull the bowls off and throw the carbs back on. That'll guarantee your getting fuel to them. You did something wrong. You can take apart and rebuild these things all you want. If you do it wrong every time you won't get anywhere. Are they stock carbs? Quote Link to comment Share on other sites More sharing options...
bball23 Posted May 14, 2012 Author Report Share Posted May 14, 2012 Pull the bowls off and throw the carbs back on. That'll guarantee your getting fuel to them. You did something wrong. You can take apart and rebuild these things all you want. If you do it wrong every time you won't get anywhere. Are they stock carbs? Yea I must have done something wrong but i cant see what it can be. Im going to take a look at it again right now. Quote Link to comment Share on other sites More sharing options...
VoOK Posted May 14, 2012 Report Share Posted May 14, 2012 Choke tube? Quote Link to comment Share on other sites More sharing options...
bball23 Posted May 14, 2012 Author Report Share Posted May 14, 2012 I messed with the carbs and I guess the floats were stuck and now it starts just doesnt stay idling for a long time like it did before but thats because I messed with the slides... Thanks for all the help everyone. Quote Link to comment Share on other sites More sharing options...
