no spark
jayc
Bro, I'm looking for a solution and didn't think people sat around and read every topic so I started a new one. My bad. I will post pics of this bitch after I blast it with a 12 ga.
Did you test your coil? Did you test your stator? Did you check the pickup on the flywheel? Is the Key switch on? Try new plug caps?
everything is good....went from spark to no spark just from changing the thumb throttle and carbs.......i suppose s@ happens. I will go through everything.
