007banshee Posted May 9, 2012 Report Share Posted May 9, 2012 Hey guys. Complete rebuild on bike. Currently waiting for JL swinger and Fireball AArms to come in. Rode bike last week and it was fouling plugs. Here's my setup. Not sure if its airscrew or needle that needs adjustment. -Stock Head/cylinders bored. 30over -+4 timing -BR8ES plugs gapped .07 -900ft elevation at 55-65° -Stock carbs TORS removed -27.5 pilots Fatties/PC 2s -320 mains -1.5 airscrew -Uni Pods with outerwears -Clip 1 below middle. Needle has 6 notches? What brand? -32:1 oil mix with yamahlube. Did a plug chop before i took swinger and arms off. Only got to 4th wot and ran out of field. 2mm of grey line at bottom of porcelain. I will post picture's saturday of plugs. My top end seems lean if the plug is grey,not sure if i held it long enough tho. But i i cant get plugs to last a full tank, and i try to stay on it pretty hard,as it is a 2 stroke. Leakdown test was good and compression is about 125 on both. Running 93 octane also. Just not sure where to start if anyone can give me suggestions that would be awesome. Thanks! Nick Quote Link to comment Share on other sites More sharing options...
VoOK Posted May 9, 2012 Report Share Posted May 9, 2012 (edited) 32:1 may be too much. I'm not too keen on jetting, sorry. Edited May 9, 2012 by VoOK Quote Link to comment Share on other sites More sharing options...
007banshee Posted May 9, 2012 Author Report Share Posted May 9, 2012 Plugs are a little wet. Not drenched but wet. One plugs ring is thicker then the other, cant remember what plug was in which cylinder. Ill go up a clip and report back. Might be a week or two, but ill get pics and try another chop until then. Quote Link to comment Share on other sites More sharing options...
Surfrjag Posted May 9, 2012 Report Share Posted May 9, 2012 gap plugs to .020 go down on main unless its ported. Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted May 9, 2012 Report Share Posted May 9, 2012 What pipes are you running? What does the spark look like? Colorwise. Quote Link to comment Share on other sites More sharing options...
007banshee Posted May 9, 2012 Author Report Share Posted May 9, 2012 FMF Fatties, Powercore 2s. Spark is good and blue. Ill ohm my coil this weekend. Plugs gapped to spec which is. 07 or 30mm if i can remember right. Thanks guys ill get ya pics soon! Quote Link to comment Share on other sites More sharing options...
WINDYCITYJOHN400 Posted May 10, 2012 Report Share Posted May 10, 2012 Well....with it being a fresh rebuild....could it just be crazy wet with assembly oil? I oil every moving part before it goes together, so it's got ALOT of oil in it when it first fires up. I'll sometimes foul a plug while I'm breaking in the motor or in the first 1/2 hour of riding. Or are you talking after a number of hours of riding? Quote Link to comment Share on other sites More sharing options...
007banshee Posted May 10, 2012 Author Report Share Posted May 10, 2012 I lube everything pretty good too but it has probably 5-10 hours on it. Quote Link to comment Share on other sites More sharing options...
007banshee Posted May 12, 2012 Author Report Share Posted May 12, 2012 Heres a pic of my plugs guys, what causes one to have a thicker ring than the other? They are more grey, no real brown. Where do you think im at? Thanks! Quote Link to comment Share on other sites More sharing options...
007banshee Posted May 13, 2012 Author Report Share Posted May 13, 2012 What do you guys think? Quote Link to comment Share on other sites More sharing options...
Finch Posted May 13, 2012 Report Share Posted May 13, 2012 I think its time for a new camera. pretty fuzzy bud. Quote Link to comment Share on other sites More sharing options...
007banshee Posted May 13, 2012 Author Report Share Posted May 13, 2012 Haha yeah, its with my cellphone, seem to have lost my digital..... Quote Link to comment Share on other sites More sharing options...
Finch Posted May 13, 2012 Report Share Posted May 13, 2012 Ya mine focus's pretty good but try taking the pic a lil further away Quote Link to comment Share on other sites More sharing options...
Poolman Posted May 13, 2012 Report Share Posted May 13, 2012 Spark plug gap to narrow. Try 6mm or .027 Doesn't take much to foul .07 Quote Link to comment Share on other sites More sharing options...
007banshee Posted May 13, 2012 Author Report Share Posted May 13, 2012 Okay ill try that. Will report back. Quote Link to comment Share on other sites More sharing options...
