@thecribchillin Posted May 6, 2012 Author Report Share Posted May 6, 2012 so i tried disconnecting the plug going to that black box for the TORS brain........still same thing. what i did was recorded a video of what the problem is, its a short video but it gets the point across. i was trying to describe the noise but its hard to explain in letters lol so here is the youtube link, take a look and listen to see if you notice anything or have an idea what it is......again thanks guys Quote Link to comment Share on other sites More sharing options...
Jereme6655 Posted May 6, 2012 Report Share Posted May 6, 2012 That noise is the sound that the bike makes when the parking brake or TORS cause issues. If you disconnected the TORS and disconnect the parking break it will stop. Search for parking brake in the search box and follow the instructions and it will stop your problems. Quote Link to comment Share on other sites More sharing options...
@thecribchillin Posted May 7, 2012 Author Report Share Posted May 7, 2012 To be honest I wanted to remove the both of them......so I guess it kinda works out. Where can I order the removal kit for the tors system, and is it hard to remove the both of them??!? The parking brake never worked, and when I flipped it it stopped moving so its pointless really.....get back to me, any tip helps! Thanks Quote Link to comment Share on other sites More sharing options...
MarineNYC Posted May 7, 2012 Report Share Posted May 7, 2012 I had the same problem. Turned out to be my gap on my flywheel pickup. The screw rusted. And it loosened up. Take your cover off. Losen the pickup screw put a bussines card in between the pickip and flywheel. Tighten screw. Then pull out the card. Quote Link to comment Share on other sites More sharing options...
