Flip rear rims
Philippos
ok, well you already have a +2 axle in the rear, i dont think its necessary to go wider than that in the rear. You could flip your fronts though, VoOK has it and im planning on doing the fronts as well. The only thing is the valve stem will hit the caliper so you need to dismount the tire, drill a hole and mount a valve stem on the inside of the rim and flip the other one inside out so it soesnt hit the caliper.
I think you mean flip the fronts. because flipping the rear wheels would make the bike narrower. They are wider in the original stock position, i actaully just measured too.
Not factory. You probably have offset rims already. Of they are stock then go ahead you'll be fine
