DDShee Posted April 30, 2012 Report Share Posted April 30, 2012 so i bought my banshee as a project for $1200 the kid said it needed a stator so i went for it. Well i got the new stator, and it runs, like shit. lol But i got it to run decent enough to take for a ride, so i took it out. But around one of the head studs, its leaking coolant. So thats probably why its running like hell. But i noticed that its dripping gas out of the vent line from the bottom of the carb, only when running also. Just for a background it has some no name pipes, and what look like FMF powercore I's, adj timing plate, trinity stage IV single carb kit, v force (3?) reeds, and a pro design cool head with 20cc domes. If anyone has any advice on what i should do next PLEASE speak up. Quote Link to comment Share on other sites More sharing options...
BigRed350x Posted April 30, 2012 Report Share Posted April 30, 2012 so i bought my banshee as a project for $1200 the kid said it needed a stator so i went for it. Well i got the new stator, and it runs, like shit. lol But i got it to run decent enough to take for a ride, so i took it out. But around one of the head studs, its leaking coolant. So thats probably why its running like hell. But i noticed that its dripping gas out of the vent line from the bottom of the carb, only when running also. Just for a background it has some no name pipes, and what look like FMF powercore I's, adj timing plate, trinity stage IV single carb kit, v force (3?) reeds, and a pro design cool head with 20cc domes. If anyone has any advice on what i should do next PLEASE speak up. Ditch the 2into1 carb kit and get a set of dual's like keihin 28's or 33 pwk's. Something like that. Single-carbs suck. For the mean-time the fuel coming out the line is from improper float height or your needle valve isn't closing properly. yank the carb and tear it all apart and clean the shit out of it. I would also yank the head and replace your o-rings. Both are easy jobs. Next thing would be to get it jetted right. the poor performance is probably due to crappy jetting on top of your other issues. make sure your timing plate is set at +4 for starters. Jared Quote Link to comment Share on other sites More sharing options...
MyNameIsMud Posted April 30, 2012 Report Share Posted April 30, 2012 Ditch the 2into1 carb kit and get a set of dual's like keihin 28's or 33 pwk's. Something like that. Single-carbs suck. For the mean-time the fuel coming out the line is from improper float height or your needle valve isn't closing properly. yank the carb and tear it all apart and clean the shit out of it. I would also yank the head and replace your o-rings. Both are easy jobs. Next thing would be to get it jetted right. the poor performance is probably due to crappy jetting on top of your other issues. make sure your timing plate is set at +4 for starters. Jared good info there. what is the 2-1 setups good for? also while on the 2-1 subject how are those pipes? Quote Link to comment Share on other sites More sharing options...
DirtDiggler69 Posted April 30, 2012 Report Share Posted April 30, 2012 good info there. what is the 2-1 setups good for? also while on the 2-1 subject how are those pipes? I run a 2-1 Intake with a 33 pwk , and I love it . Simple to maintain . Yeah you sacrifice top end , but I ride the Dunes and Trails and it suffers no where . If I were you I'd keep the 2-1 . I also have a Motofast 2-1 pipe , and It's perfect for where I ride , it has a nice low to mid range powerband , It falls off on the top end a bit , but I like that low to mid range power , makes it kinda 4 strokey , more predictable I guess you could say. Quote Link to comment Share on other sites More sharing options...
toytech Posted April 30, 2012 Report Share Posted April 30, 2012 single carb and single pipe belong on a blaster, banshees are meant for 2 hence the twin cyls. two carbs are easy to tune, just do some researce on here, sync is importent. Quote Link to comment Share on other sites More sharing options...
Coupelx Posted April 30, 2012 Report Share Posted April 30, 2012 single carb and single pipe belong on a blaster, banshees are meant for 2 hence the twin cyls. two carbs are easy to tune, just do some researce on here, sync is importent. exactly. it is no harder to tune than 1 carb. couple extra steps? sure, but no harder. that motofast pipe falls off on the top end more than a "bit" and duning is where you want some top end. Quote Link to comment Share on other sites More sharing options...
DDShee Posted May 4, 2012 Author Report Share Posted May 4, 2012 what are you guys talkin about a motofast pipe? mine are fmf duals. Quote Link to comment Share on other sites More sharing options...
Burt Reynolds Posted May 7, 2012 Report Share Posted May 7, 2012 (edited) If you have used a 1:2 carb kit and lost a lot of power,your doing it wrong. 2-4 more hp bottom end,2-4 less on top on the same port/pipe setup. It is a trail mod,not a drag/top end mod. Edited May 7, 2012 by Burt Reynolds Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted May 7, 2012 Report Share Posted May 7, 2012 Yamaha has been doing it right for a long time 2s, 2cyl, 2 carbs. Other than some half ass old ass snomobile, show proof of multi cyl 2s with single carbs. I'll go 5:1 on ANYTHING you can find Quote Link to comment Share on other sites More sharing options...
Burt Reynolds Posted May 7, 2012 Report Share Posted May 7, 2012 Here are the charts from a crank dyno,not rear wheel. Shows gains in the low,and losses in the high,just like any trail mod or low end mod will do. Im not saying that a single carb will make your banshee lay golden eggs,im saying there are enough benefits to single that some of us trail guys prefer it. Quote Link to comment Share on other sites More sharing options...
yamahaty Posted May 7, 2012 Report Share Posted May 7, 2012 Just throwing my 10 cents in, my buddy had a dirtbike doing the same thing and it was just the head gasket. Quote Link to comment Share on other sites More sharing options...
Coupelx Posted May 7, 2012 Report Share Posted May 7, 2012 Yamaha has been doing it right for a long time 2s, 2cyl, 2 carbs. Other than some half ass old ass snomobile, show proof of multi cyl 2s with single carbs. I'll go 5:1 on ANYTHING you can find Exactly. Another case of people reinventing the wheel. Race teams spend millions to get the Carb as close to the valve/cylinder as they can. Maybe there's something to it! Quote Link to comment Share on other sites More sharing options...
BigRed350x Posted May 8, 2012 Report Share Posted May 8, 2012 Just spray it. Problem solved. Quote Link to comment Share on other sites More sharing options...
Burt Reynolds Posted May 8, 2012 Report Share Posted May 8, 2012 Exactly. Another case of people reinventing the wheel. Race teams spend millions to get the Carb as close to the valve/cylinder as they can. Maybe there's something to it! Well then i guess we should stick to the stock a arms/swinger/shocks/pipe/head/porting/colors/tires wheels chain ect... because if yamaha has been doing it that way since the dark ages they must be perfect for everyone in stock form. Ill pay pal anyone 20 bucks if they can tell me any serious drawbacks to having a single carb on a TRAIL bike,as a TRAIL mod. Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted May 8, 2012 Report Share Posted May 8, 2012 (edited) Ill pay pal anyone 20 bucks if they can tell me any serious drawbacks to having a single carb on a TRAIL bike,as a TRAIL mod. Cause it's gay as http://content8.flixster.com/photo/12/98/53/12985342_ori.jpg&imgrefurl=http://www.rottentomatoes.com/celebrity/liberace/&h=460&w=345&sz=100&tbnid=nLGkBakQaHX40M:&tbnh=91&tbnw=68&zoom=1&docid=T09XmnCktLTdxM&hl=en&sa=X&ei=WQepT93_McPAtgfx2ZiiAg&ved=0CIUBEPUBMAQ&dur=4024http://content8.flixster.com/photo/12/98/53/12985342_ori.jpg'>http://www.google.com/imgres?imgurl=http://content8.flixster.com/photo/12/98/53/12985342_ori.jpg&imgrefurl=http://www.rottentomatoes.com/celebrity/liberace/&h=460&w=345&sz=100&tbnid=nLGkBakQaHX40M:&tbnh=91&tbnw=68&zoom=1&docid=T09XmnCktLTdxM&hl=en&sa=X&ei=WQepT93_McPAtgfx2ZiiAg&ved=0CIUBEPUBMAQ&dur=4024http://content8.flixster.com/photo/12/98/53/12985342_ori.jpg http://content8.flixster.com/photo/12/98/53/12985342_ori.jpg Edited May 8, 2012 by Larry's Shee Quote Link to comment Share on other sites More sharing options...
