AKheathen Posted November 17, 2012 Report Share Posted November 17, 2012 Solder an led on the end of a ac power cord. Plug it in and swing it around in a circle. You can really see the 60hz affect. The circle is made up of a bunch of dashes. haha, i do this every time i plug in a new set of led christmass or rope lights. what's cooler, you can see them phase on/off and which lights are different polarity when wearing 3d shutter glasses.... cheap entertainment ftw Quote Link to comment Share on other sites More sharing options...
SpecialEd 05 Posted November 17, 2012 Report Share Posted November 17, 2012 (edited) LiPo batteries have come a long way, even the cheap ones. Haven't seen any 'go-up' at the RC events I've been to. You get a bit more safety with the hardcase ones too. So long as you don't exceed the maximum discharge rate you will be fine. The 'C' rating mulitplied by the capacity of the battery in amps gives you the maximum discharge rate. So 5000mah 20C will supply a maximum of 100 amps continuous power but only for 3 minutes at that current (or 2 amps for 2.5 hours). More than enough for a couple of CREE LED's. Dedicated AC/DC LiPo chargers are pretty cheap too these days, I already have one. And as long as you charge them at the correct rate you'll have no problems, usually 1C (5000mah @ 5 amps) They can even be charged off a car battery if you're on a trip. Edited November 17, 2012 by SpecialEd 05 Quote Link to comment Share on other sites More sharing options...
AKheathen Posted November 17, 2012 Report Share Posted November 17, 2012 so, they are being used with current limitation. in rc, they are typical with brushless in the begining, which comes inheirently with the 3-phase controller to make it work. what i was worried is if they were being free-ran like a standard battery Quote Link to comment Share on other sites More sharing options...
SpecialEd 05 Posted November 17, 2012 Report Share Posted November 17, 2012 so, they are being used with current limitation. in rc, they are typical with brushless in the begining, which comes inheirently with the 3-phase controller to make it work. what i was worried is if they were being free-ran like a standard battery In RC they will work on any brushless or brushed setup. Even in a scale rock crawler where they draw very little current they'll run for 2-3 hours on a 5000mah battery. I don't think under discharging is going to be a problem and the supply on a 4s LiPo is definitely 14.8 volt DC so you won't need any special kind of controller, just connect red/+ve & black/-ve. The only thing you could add is a low voltage cut-off to eliminate over discharging but I think you'd definitely notice the lights drop before then. Quote Link to comment Share on other sites More sharing options...
atvrider85 Posted May 6, 2014 Report Share Posted May 6, 2014 Just curious if the lights are still working? And also what brand were they? Thanks Quote Link to comment Share on other sites More sharing options...
yamaha_4_life Posted May 8, 2014 Report Share Posted May 8, 2014 ^^^^ Yeah I'm curious also. Quote Link to comment Share on other sites More sharing options...
Digitall Posted December 22, 2015 Report Share Posted December 22, 2015 Have these lights blown or are they still running without dc conv? Quote Link to comment Share on other sites More sharing options...
Deadbeat Posted December 23, 2015 Report Share Posted December 23, 2015 this bike was parted out over a year ago Quote Link to comment Share on other sites More sharing options...
setkiki Posted March 4, 2019 Report Share Posted March 4, 2019 There is a very comprehensive rectifier on allicdata Quote Link to comment Share on other sites More sharing options...
