sheerider11 Posted May 1, 2012 Report Share Posted May 1, 2012 How do i tighten my chain? With bailing wire How much oil should I put in my trans?just add water tell its full, it will be fine What kind of oil should I use? Again water works fine what are the best pipes to run? Stock pipes and no scilencers Who does the best porting? Your mom How do i check pick up gap? Tape measure How do i know if my flywheel is still good? If you can throw it at a wall and it bounces Which domes should I run? Just make some domes from a pop can What kind of porting should I get? Porting is a waste of time and money Can my bike beat this rappy 700? Not a chance How much HP do I have? 350hp give or take Do I need race fuel? No just run ethanol Does race fuel help HP? It adds about 27hp on an all stock bike Should I port my own cyl's with cardboard templates? It's pretty simple, go for it What is a leakdown test? That's when you run your bike without the filter and see if your carbs fill with dirt How do I check squish? Jump up and down on the seat How far can I go on 1 tank of fuel? 351.4 miles soda can domes and a bounce squish test. I new there had to be more easy free mods, and a easier way to do a squish test. Quote Link to comment Share on other sites More sharing options...
twistingixxers Posted May 15, 2012 Report Share Posted May 15, 2012 soda can domes and a bounce squish test. I new there had to be more easy free mods, and a easier way to do a squish test. You can always get a big girl to sit on your piston....Squish...Squish..Test SAT Quote Link to comment Share on other sites More sharing options...
