cog ratios
A you wont find a hub that will allow a 33 on the rear even a honda hub
B 4 teeth in the rear is 1 in the front so -8 in the rear is going up in the front +2 so basically all you are doing is leaving the rear alone and adding a tooth in the front.
mentioning not wanting SA comments only provokes ppl to make them around here.
gear ratio is gear ratio wheather you achieve the ratio you want with a small front/small rear or large front/larger rear combination doesn't matter for the performance. The chain will appreciate you running a larger front sprocket to achieve your desired gear ratio.
-Brandon
-Brandon
10-4
Thanks Brandon
Running stock now, looking to gain top end without killing the bottom end.
How about a 13/33? -1 in front -8 in back
Should balance out right, 1:2?
What kind of motor are you running? That is a pretty low Ratio. (Stock- 2.928 15/40 -2.857 13/33- 2.538)
A 16/41- 2.562 or a 16/40- 2.500 would get you in the same range though.
