Finally Time for A suspension update
eldreder
Well, the wait was definitely worth it, my parts showed up yesterday from stellar and i started the dissassembly process today to start the suspension overhaul.
Here's some pics of today's progress:
Pic Tim sent me of my parts coming out of powdercoat
Here's another peek at the parts
whoops, this will be fun to fix :confused:
need to get a 2 jaw puller to get these tie rod ends out
stopped there for today, hopefully i'll be able to get a good deal on a 2 jaw puller so i can get this thing finished up :cheers:
Edited by eldreder
Lube them up with penetrating oil, and let sit for a while. Then give it a good couple whacks with a hammer while pushing down on the tie-rod ends. There is probably some rust in there.
If you are just putting new tie rods on, there is no need to take both the tie-rod ends out of the steering stem. Just thread new tie rods on and your golden. FYI!
well made some more progress after all,
thought this would do the trick:
then this happened:
so then i found this at work:
it seemed to work alright, not the perfect tool for the job, but none the less
looks like i might need some new brake pads:
here it is with everything off:
here's some of the old junk:
here's a real good one, if you can't tell, the ball joint popped out, so i had a washer welded over it to hold it in, seems pretty safe :confused:
more parts:
that's all for now, hopefully some re-assembly pics tomorrow :cheers:
Damn nice parts. Get some pics of that stuff on the bike. Usually the tie rods and ballpoints will pop right out with a couple wacks of a bfh. Don't hit the actual tie rod you hit the side of the knuckle where the tapered shaft goes through it. Usually pop out after that. I never have used a puller or fork to remove them. Cars or quads.
Thanks guys, I was able to get the tie rod ends out with the puller, but i ended up just using a hammer on the ball joints.
Also I posted the pics correctly right? You guys can see them without having to click the links ?
What size are those Js? What did they cost and how long to get them? :cheers:
My son missed out on some Js on Egay recently :cry:
The j's are +2 +1 and I paid around 500 for them and it took about 6 weeks to get them, but it woulda been like 5 weeks had they not had an issue with powder coat.
It was definitely worth the wait though these are awesome !
