Tz and max load...
zach45
I read somewhere on here that a to barring is no good unless you have straight cuts... Is this true??
After the summer in going to send my crank to be true/welded and was wondering about this?
4mil ported 20cc domes...
I run a TZ and maxload and dont have straight cuts , I cant see why a better bearing would make any differance .
The problem found is when you run the tz on the pto side without straight cuts. TZ beaings are a roller type bearing and therefore have no resistance to side loading. Your stock helical cut gears side load the crank when you're on the throtte. This can/will exert more force on the rod pin area as the crank is loaded. My recommendation is to run the 10 ball Maxloads with stock gears or a TZ on the stator side not the PTO side.
-Brandon
