dmfisher71 Posted April 25, 2012 Report Share Posted April 25, 2012 curious what voltage does the stator put out to the rectifier to run the headlights... 12 volts i assume...please correct me if i am wrong Quote Link to comment Share on other sites More sharing options...
sheerider1026 Posted April 25, 2012 Report Share Posted April 25, 2012 there is no rectifier.. just a voltage regulator.. 12-14v AC.. u can dloat the ground on the stator and ad a rectifier to convert to 12v dc if you like Quote Link to comment Share on other sites More sharing options...
dmfisher71 Posted April 25, 2012 Author Report Share Posted April 25, 2012 there is no rectifier.. just a voltage regulator.. 12-14v AC.. u can dloat the ground on the stator and ad a rectifier to convert to 12v dc if you like how do i convert it over to DC.... is there instructions to do this anywhere.... i got me a set of nice LED headlights off a forklift that are nearly identicle to the stock lights Quote Link to comment Share on other sites More sharing options...
Coupelx Posted April 25, 2012 Report Share Posted April 25, 2012 the stator is capable of 40+ vAC if unregulated. Quote Link to comment Share on other sites More sharing options...
So Cal Suspension Posted April 25, 2012 Report Share Posted April 25, 2012 the stator is capable of 40+ vAC if unregulated. Correct. Typically an unregulated stator puts out 37-40VAC at WOT, 7-9VAC at idle. Quote Link to comment Share on other sites More sharing options...
dmfisher71 Posted April 26, 2012 Author Report Share Posted April 26, 2012 Correct. Typically an unregulated stator puts out 37-40VAC at WOT, 7-9VAC at idle. thats cool i just need to know how i convert it from ac to dc current.. the lights i have are 12 volt dc Quote Link to comment Share on other sites More sharing options...
erickson483 Posted April 26, 2012 Report Share Posted April 26, 2012 Use the search!!! AC to DC conversion is a little involved. However, since I'm a nice guy I found you this for you. http://bansheehq.com/forums/index.php?showtopic=92899&st=0&p=800737&hl=+conversion%20+&fromsearch=1entry800737 Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted April 26, 2012 Report Share Posted April 26, 2012 the stator is capable of 40+ vAC if unregulated. Yea it is pretty cool when you forget that you un hooked the regulator and you give it a rev with the headlights on. Nothing like having a set of PIAA H6M Bulbs going off like one time use Flash Bulbs. Quote Link to comment Share on other sites More sharing options...
So Cal Suspension Posted April 26, 2012 Report Share Posted April 26, 2012 Yea it is pretty cool when you forget that you un hooked the regulator and you give it a rev with the headlights on. Nothing like having a set of PIAA H6M Bulbs going off like one time use Flash Bulbs. Haha, BUT, they were bright for a split second before they blew, right? Quote Link to comment Share on other sites More sharing options...
