Shaving the stock cylinder head .040
  • Replies 44
  • Created
  • Last Reply
Top Posters In This Topic
I was afraid it would be too tight. Ill do a squish test to be sure before i pull the head. I thought the stock squish height was around .080 but im probably wrong. I hope it hasnt damaged my pistons yet. Ive only put about 1 1/2 hours on the engine so far and only wound it up twice. Thats when the detonation occured on the top end and i havent ran it since.
I hit my thumb with a hammer once, then I hit it again just to be sure that's why it hurt. :shootself::jesterlaugh::cheers:
Im running a stock head thats shaved .040 and im getting some detonation on top end. Im running ported cylinders and 5 degrees timing with 340 mains in stock carbs also. Will a 50/50 race fuel and pump gas mix be ok?
Set the timing to 4^ and run race fuel ....don't run it anymore until you fix the detonation problem or you will pop that motor !
having a stock head done up is less than $100. The more i research and play with my setup the more i learned that dome design is critical for a proper setup. the one mull engineering did for me made all the difference in the world. the bike has loads more power off the pipe and a very nice transition. i rode trails for about an hour just cruising off the pipe with the powerband just a blip of the throttle away.
I plan to throw the other stock head on it for now and send the shaved head to get the domes cut for propper squish if it can be done cheap enough. I dont want to tie up much cash in the head because ide just replace it with a cool head and domes first. Ill see tomorrow where my squish height is at and get back with the numbers so every one will know for sure if .040 is too much to remove from the stock head.
So why, if you are gonna spend the money to have the stock head redone, would you then run out and buy a coolhead (and craptastic orings)? pick one and be done.
I dont understand why everything needs to be so complicated with newbies.
I dont plan to run out and buy a cool head with domes if i get the stock head machined. Im just lookin to set it up once and be done but i dont have alot to spend. Im probably gonna send a stock head to mull eng. and have it done and run it from now on.
reliability = stock head and headgasket.
I run the hell out of mine. beat it like it owes me money.
