Help on jetting after rebuild
JdmhatchR
Hi all,
Since I'm new I want to ask help on jetting my shee after my rebuild...
It's a 06 banshee:
Vitos superstock 050
Vforce 3
Aluminium airbox with 2 Unipods (no lid on the airbox)
DMC 916 pipes
stock carbs
I live at 357.6ft above sea level. (Belgium)
For example: Before the rebuild I've had the toomeys T5 and a stock airbox with K&N (no lid on airbox) ,and it was jetted perfect on a 250 main.
Done by a local shop, plug chop was perfect...
Now I want to do it myself, if you could give me directions on the main jet, that would be nice!
Greets
well just for a starting point id try somewhere between 280-310 on the mains and a 27.5 pilot 1-1/2 out on air srew.. if you said "250" were perfect before, i dont think much will change by just doing a rebuild with vito piston(i could be wrong, not real familuar with the vito pistens) but since you are running a different box and filter setup id start a little high on the mains and adjust accordingly to the plug chop readings! good luck!!
