phxAZbanshee Posted April 20, 2012 Report Share Posted April 20, 2012 I'm looking for suggestions on jet size. Im running all stock besides, pro flow adapter with uni 2 to 1 filter and no airbox lid. I'm at about sea level and temps. are from about 70-110 degrees. Currently im running 230 mains and 25 pilots but bike wont seem to idle. And left carb keeps flooding out. Quote Link to comment Share on other sites More sharing options...
special06shee Posted April 20, 2012 Report Share Posted April 20, 2012 i think jetting should be fairly close.. pull carbs off and check float heights.. Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted April 20, 2012 Report Share Posted April 20, 2012 Clean carbs one at a time as parts are carb specific, set float level. Start at 1 1/2 out on air screw. I prefer soaking carbs but completely dissassemble , carb spray and compressed air will work. Be sure to take pilot jet out, make sure the jet is open. Sync carbs best you can and do a plug chop. Quote Link to comment Share on other sites More sharing options...
