Carb issue ?
I tried searching for some help but im baffled on this banshee issue! so i picked up a 96 banshee for 600 bucks that did not run. The bike has spark 120psi in both cylinders and is bone stock! i rebuilt both carbs disconected thetors and doubble checked everthing. The bike will only start being towed or with a splash of gas but will not stay running what could be the prolbem ? BTW i also have a stock 99 banshee that runs like a top that i rebuilt with help from this forum. should i try to swap the carbs out between the two to see if that helps ? im running out of beer and patience
thanks for any help!
Yes, the plugs are "wet" and you can smell fuel at the tail pipes. Bike has very strong spark. Just won't start/stay running. Me and buffalo-banshee have verified this.
We have swapped known "good" plugs and still, no dice. Prior to this, the machine would start and run with the choke out, relatively well. Now, nothing. Something has to be screwed with the carb(s).?
Check if the choke tube that goes from carb to carb is in place. Did you guy check the carb if they are sync? Also did you guys mix up the float bowls? There is a Left one & Right one the left one has the little tube in it. IF this all check out then disconnect the tors box under the left side of the gas tank and see if that works. good luck & keep us posted.
