Is my clutch slipping?
Went for a ride yesterday and this is the first time I've felt this happen. I was on asphalt getting into it pretty good. When I hit 6th and let the clutch out getting back on the throttle I felt a slight jumping feeling. Kinda like the clutch was slipping and grabbing again. My chain is adjusted correctly, fluid is clean and fresh. Whenever I felt a clutch slip it reved and didnt go any where. In this situation the motor sounds good but I feel it. Just trying to get some ideas on what to look for.
if you hear the motor reving up and your tires arent slipping and your not pickin up speed. chances are its your clutch slipping.
motors not reving with out picking up speed. I doubt i am spinning in sixth gear on asphalt.
Edited by robert0762
