What do you think about my Jetting?
sdatver
Ok I just thought I would check to see if im close on jetting before I take it out.
I bought this quad used and it changed hands a few times before me and ran great so I have yet to get into the engine to know any engine mods.
Ok I run a K&N air filter stock airbox with snorkel removed and vented lid (several 1 or 1.5" holes drilled all along the outside edge of lid)
Stock Carbs
Toomey T5's
Reeds unsure if they are stock or not but stock cages are stock and pedals are clear
Pilots- 25
Mains- 310
Needle Clip is #2 spot
Elevation 1300ft
Edited by sdatver
Doesnt sound bad to me. What do your plugs look like? Did you do a plug chop?
No not yet just waiting for my control arms from Stellar so i can take it out and ride. Will do a plug chop when I get them put on just trying to get close while I have it in my shop. I usually keep it out at our farm and it is a lot easier to work on it in the shop. But as soon as i get it out I will do a plug chop. Thanks for the reply.
Has it had any portork? Assuming you have no air leaks I would think you would be fine prolly a bit rich at that elevation. Should be a good place to start then work your way down based on the plug chops. Unless its ported then u prolly won't wanna lean it much if any. I'm around 900 feet here and some friends have stock carbs with aftermarket pipes and air filters and they are in the 270 280 range
