Take it to the next level
if i will need to go up a piston size with boring a bit the cylinder. will i need anything else except pistons?
here in cyprus its a bit hard to find parts so ebay is ok.ive been long years been on ebay ordering all sorts with no prob. if something goes wrong from sellers side most of the times a replacement or refund is issued
Pistons,rings, wrist pins, wrist pin bearings and wrist pin circle clips. It is pretty normal to replace all with a new set of pistons. Some people will reuse the wrist pins and bearings but for the little bit extra, it is not worth the chance you take if one fails with your new top end. Like was stated to you in earlier post, you really should have your cylinders checked for size and roundness. New piston and rings does not do much good if you have bad/wore out bores in your cylinders. Good luck
  • 3 weeks later...
