Give us a call or any of the other HQ sponsors will be glad to help you.
Noss / FAST head because it is 2 piece. It allows you to visually conferm that the domes and o rings are properly in place. You can set a dome over each cylinder at a time. Then slide the base shell down over the domes. The install the top half. With a once pice head you have to have the domes in the head with all the o rings in place and slide it as an assembly down over the studs.
