ticktock Posted April 10, 2012 Report Share Posted April 10, 2012 I haven't tightend it yet. I was sitting on it and I had a buddy wiggle it. about 2 inches of play. I'm thinking of taking out a link. stock swinger/104 chain if you need to take a link out at 104 on a stock swinger, its time to get a new chain. Recommend changing the sprockets too, running that loose eats them up! Call Wildcard, They stock good o-Ring chain fairly cheap and it has a high tensile strength. Adam Quote Link to comment Share on other sites More sharing options...
bansheeyfz450 Posted April 10, 2012 Author Report Share Posted April 10, 2012 if you need to take a link out at 104 on a stock swinger, its time to get a new chain. Recommend changing the sprockets too, running that loose eats them up! Call Wildcard, They stock good o-Ring chain fairly cheap and it has a high tensile strength. Adam Everything on the rear is new. front/rear sprocket, chain, swing arm bearing, axle bearings, axle, front/rear chain slider, rollers, brake disc. Also maybe i should have mentioned this, gearing is 14/40 Quote Link to comment Share on other sites More sharing options...
erickson483 Posted April 10, 2012 Report Share Posted April 10, 2012 (edited) 104 length is stock chain length but your rear gear is smaller than stock. Lose a link if you're tensioners are maxed out Edited April 10, 2012 by erickson483 Quote Link to comment Share on other sites More sharing options...
bansheeyfz450 Posted April 10, 2012 Author Report Share Posted April 10, 2012 104 length is stock chain length but your rear gear is smaller than stock. Lose a link if you're tensioners are maxed out stock is 14/41. I didnt think 14/40 made that much difference, but maybe it does? Quote Link to comment Share on other sites More sharing options...
ticktock Posted April 10, 2012 Report Share Posted April 10, 2012 Everything on the rear is new. front/rear sprocket, chain, swing arm bearing, axle bearings, axle, front/rear chain slider, rollers, brake disc. Also maybe i should have mentioned this, gearing is 14/40 stock is 14/41 do a center to center measure and then use a chain calculator. If its all new with the smaller sprocket you could get away with cutting a link out, but you might need a half link. Adam Quote Link to comment Share on other sites More sharing options...
bansheeyfz450 Posted April 10, 2012 Author Report Share Posted April 10, 2012 104 length is stock chain length but your rear gear is smaller than stock. Lose a link if you're tensioners are maxed out the long bolts are almost all the way in. which i guess is maxed out. Quote Link to comment Share on other sites More sharing options...
bansheeyfz450 Posted April 10, 2012 Author Report Share Posted April 10, 2012 stock is 14/41 do a center to center measure and then use a chain calculator. If its all new with the smaller sprocket you could get away with cutting a link out, but you might need a half link. Adam Center to Center? Center of front/rear sprocket? Where would I find a chain calculator? Quote Link to comment Share on other sites More sharing options...
erickson483 Posted April 10, 2012 Report Share Posted April 10, 2012 I wouldn't think 1 tooth on the back would be too noticeable in your chain tensioning. Did you compare your new chain to your old one? Quote Link to comment Share on other sites More sharing options...
bansheeyfz450 Posted April 10, 2012 Author Report Share Posted April 10, 2012 I wouldn't think 1 tooth on the back would be too noticeable in your chain tensioning. Did you compare your new chain to your old one? No, I didn't. But it had 13/41 gearing on it. And actually the chain tensioners are the same as b4. Quote Link to comment Share on other sites More sharing options...
slothman Posted April 10, 2012 Report Share Posted April 10, 2012 you're doing something wrong if the bolts are all the way in with a 104 chain/stock gears and still have 2" of slack. Standard slack is 0.6 inches from the middle of the chain on the top side. loosen all 4 carrier bolt nuts, and tighten the chain by turning the lower two bolts clockwise. Are you sure you have routed the chain correctly? Like this: O - - - - - O - - - - O Quote Link to comment Share on other sites More sharing options...
shakar Posted April 10, 2012 Report Share Posted April 10, 2012 (edited) nice diagram^^^^ not the best solution here ive seen people lenghen the lil ajustment slot.so the carrier can slide in farther in. never tried it myself though....... goodluck Edited April 10, 2012 by shakar Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted April 10, 2012 Report Share Posted April 10, 2012 Is it safe to connect a half link to the master link? Quote Link to comment Share on other sites More sharing options...
camatv Posted April 10, 2012 Report Share Posted April 10, 2012 im not saying SHIT unless you paypal me 15 bucks. am i the ONLY one that caught the " my buddies sitting on it and i'm wigglin" it???!?!?!?!?! isnt that a dutch rudder?? ohman.. Quote Link to comment Share on other sites More sharing options...
Nightmare Posted April 10, 2012 Report Share Posted April 10, 2012 never a dull moment around here Right, i love it Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted April 10, 2012 Report Share Posted April 10, 2012 im not saying SHIT unless you paypal me 15 bucks. am i the ONLY one that caught the " my buddies sitting on it and i'm wigglin" it???!?!?!?!?! isnt that a dutch rudder?? ohman.. bahahaha!!!! I had to urban dictionary that! And that's somewhat right Quote Link to comment Share on other sites More sharing options...
