skippy Posted April 8, 2012 Report Share Posted April 8, 2012 the other day i was out riding in my pasture and it felt like my chain was trying to jump a little and then somthing locked up in the transmission can wont allow the quad to move under its own power but it will run and idle all day after taking the chain off. so i guess my question is, does any one know of a good place to get transmissions of banshee or does any one know what else could be wrong Quote Link to comment Share on other sites More sharing options...
AKRACIN Posted April 8, 2012 Report Share Posted April 8, 2012 the other day i was out riding in my pasture and it felt like my chain was trying to jump a little and then somthing locked up in the transmission can wont allow the quad to move under its own power but it will run and idle all day after taking the chain off. so i guess my question is, does any one know of a good place to get transmissions of banshee or does any one know what else could be wrong I Got my complete pro-mod trans by looking on eBay. I went with WCR, Great customer service, great price, great product. Hope this helps. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted April 8, 2012 Report Share Posted April 8, 2012 You'd be better staying away from WCR. It's hit or miss with them. Really, you need to tear it apart and see what's wrong. It could just be a shift fork. Quote Link to comment Share on other sites More sharing options...
Mustang_Gay81 Posted April 8, 2012 Report Share Posted April 8, 2012 Banshee has the simplest trans to work on of any bikes or atvs ive had shouldnt be hard once you open it up to see whats not playing well with the others. Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted April 8, 2012 Report Share Posted April 8, 2012 Unless I'm sofa we todd did, your description sounds more like the axle, because it seems fine with chain off. Or maybe take the pressure plate off the clutch and try spinning a shaft and shift it thru the gears. Might save you unecessary work, or confirm you have to pull the motor. Quote Link to comment Share on other sites More sharing options...
skippy Posted April 8, 2012 Author Report Share Posted April 8, 2012 even with the chain off and if u put it in gear it dont sound to good and neutral is messed up allsoit will rotate a little and then bind up so that why i was guessing the tranny Quote Link to comment Share on other sites More sharing options...
Starwriter Posted April 8, 2012 Report Share Posted April 8, 2012 Sounds like the tranny is pretty screwed, but to know for sure, you need to dig into it a bit. Drain the tranny oil and see if steel chunks fall out. If so, it's screwed. If not, do as Larry suggested. You're gonna have to pull the clutch to split the cases anyway. Regardless, I wouldn't buy a tranny till you get it apart and see what's going on. Quote Link to comment Share on other sites More sharing options...
