jetting help!
Well, its basically a stock shee, barely done 20 hours since new, ive just put on fmf fattys and powercore 2 silencers, also v force 3 reeds, would like to know what jetting i should use?
Stock jetting (240 mains)
27 degrees celcius with 365 m elevation
take the lid off the air box and throw in a k&n air filter clamp on style, throw a 280 main jet in and you should be good to go. make sure you do one carb at a time so that you dont mix up the bottom carb bowls ( yes they are different), make sure choke cross over tube is back in place and ride the shit out of the bike. i would do a plug chop to make sure its dead on but this should get you very close. i had the same setup minus the vforce reeds and the bike ripped with a 270 main
all i had to do in the end was put the main jet to 240 and that was it! was a weapon!! ridden it 3 times since i did it and worked out great, powers just immense in my eyes and experience (being in australia in all of places)
