steve14733 Posted April 3, 2012 Report Share Posted April 3, 2012 hi everbody in a newbee steve from western ny,, i bought a 2001 banshee with alot of aftermarket add ons.. the front arms are aftermarket and it has works shocks. question is the tires,, lean way in like 2 or 3 inches .. something dont seem right ,,,help Quote Link to comment Share on other sites More sharing options...
strokersteve Posted April 3, 2012 Report Share Posted April 3, 2012 what do the bushings at the frame end of the arms look like? Quote Link to comment Share on other sites More sharing options...
steve14733 Posted April 3, 2012 Author Report Share Posted April 3, 2012 what do the bushings at the frame end of the arms look like? everthing is nice and tite. here is pic. anyone no what kinda arms they are,, Quote Link to comment Share on other sites More sharing options...
steve14733 Posted April 3, 2012 Author Report Share Posted April 3, 2012 everthing is nice and tite. here is pic. anyone no what kinda arms they are,, i can unscrew the big nut on the top outer balljoint to fix it,, but i would have too get a nut like the smaller thin one on the inside of balljoint to make it work right, other wise the big nut would have 1/2 the threads not even used,, like half on Quote Link to comment Share on other sites More sharing options...
do-work-son Posted April 3, 2012 Report Share Posted April 3, 2012 Looks like you got one shock at a higher setting that the other it may just be the picture or possible a low Tire. The gf yfz get a pretty good lean when a rear tire goes flat Quote Link to comment Share on other sites More sharing options...
nastyracing Posted April 3, 2012 Report Share Posted April 3, 2012 its called camber most people set up exactly like that 4% like your is for motor cross easier to corner and when accelerating out of corner tires squar up as front end lifts leave them as is trust me . i run a very drastic camber on my bike helps bike turn way better best riding shee ive ever rode trust me i try all different set ups and you will be pleased dont worry about the look. it does wear tires a bit though. this is 6% on mine and most people say dont use that much but i have found works out great for me.... most places charge almost 100$ to set front up that way atleast shops do. Quote Link to comment Share on other sites More sharing options...
shakar Posted April 3, 2012 Report Share Posted April 3, 2012 (edited) should nt both arms be set the same.......1 of his looks like its alot more cocked then the other??maybe for round track??maybe jus pic? heres a diy link. not sure it a shee but may help goodluck http://avengeratv.co....html#alignment Edited April 3, 2012 by shakar Quote Link to comment Share on other sites More sharing options...
steve14733 Posted April 3, 2012 Author Report Share Posted April 3, 2012 Looks like you got one shock at a higher setting that the other it may just be the picture or possible a low Tire. The gf yfz get a pretty good lean when a rear tire goes flat thanx guys mine is about like the monster set up and im gonna motocross it so i guess i ll leave it.. and also thanx for the link that is a great tool to have cheers Quote Link to comment Share on other sites More sharing options...
