421alkybanshee Posted April 2, 2012 Report Share Posted April 2, 2012 hey everyone, i noticed a type of knocking sound on one of my banshees, its not real loud but if i give a throttle and let off i hear it more on the stator side. I puller cover off and i noticed i can turn the flywheel back and forth in small motions and kinda hear a clanking noise?? anyone/ help greatly appreciated Quote Link to comment Share on other sites More sharing options...
special06shee Posted April 3, 2012 Report Share Posted April 3, 2012 hey everyone, i noticed a type of knocking sound on one of my banshees, its not real loud but if i give a throttle and let off i hear it more on the stator side. I puller cover off and i noticed i can turn the flywheel back and forth in small motions and kinda hear a clanking noise?? anyone/ help greatly appreciated pull the flywheel.. inspect the keyway Quote Link to comment Share on other sites More sharing options...
421alkybanshee Posted April 4, 2012 Author Report Share Posted April 4, 2012 pull the flywheel.. inspect the keyway Im gonna do that next, ive pulled the pistons thinking wrist pin brg bad, but they both look good to me, crank brgs both look good, no play up down whatsoever and crank spins nicely. Im taking the cyls and pistons to my machine shop tomm to check piston to cyl diameter and see is bore is by some chance out of round???? If they check out then I guess im putting cyls back on and running it. But yes i do need to take flywheel off and check key. Thank you Quote Link to comment Share on other sites More sharing options...
WINDYCITYJOHN400 Posted April 4, 2012 Report Share Posted April 4, 2012 Yeah, that sound can often be your flywheel is loose. When you get the flywheel off (even if it was tight) give it a good shake. If it makes any noise....it's going bad too. Magnets are breaking up and coming loose. Quote Link to comment Share on other sites More sharing options...
421alkybanshee Posted April 21, 2012 Author Report Share Posted April 21, 2012 found out it was a crank bearing. i got lucky though, it didnt fly apart before i had to tear it apart. Quote Link to comment Share on other sites More sharing options...
isuckdick4blasters Posted April 28, 2012 Report Share Posted April 28, 2012 damn that could have been catastrophic, good catch bud Quote Link to comment Share on other sites More sharing options...
vulvafan537240 Posted April 30, 2012 Report Share Posted April 30, 2012 nice save Quote Link to comment Share on other sites More sharing options...
ClayAiken Posted April 30, 2012 Report Share Posted April 30, 2012 Shit that was lucky. Quote Link to comment Share on other sites More sharing options...
booxzzy Posted May 16, 2012 Report Share Posted May 16, 2012 Shit that was lucky. x2 Quote Link to comment Share on other sites More sharing options...
