DirtDiggler69 Posted March 31, 2012 Report Share Posted March 31, 2012 I see the pinned how to BUT the pictures aren't showing up . I got my shocks today and the upper mount looks like it needs to be ground down a little bit for the bolt to line up. I'm using +2 a arms so the lower mount isn't an issue . Anyone else need to grind some of the bottom Of the upper mount? Quote Link to comment Share on other sites More sharing options...
VoOK Posted April 1, 2012 Report Share Posted April 1, 2012 I see the pinned how to BUT the pictures aren't showing up . I got my shocks today and the upper mount looks like it needs to be ground down a little bit for the bolt to line up. I'm using +2 a arms so the lower mount isn't an issue . Anyone else need to grind some of the bottom Of the upper mount? I don't have those shocks but i have heard many times that you must grind a little bit off in under for these to work. Enjoy your new shocks. Quote Link to comment Share on other sites More sharing options...
Nightmare Posted April 1, 2012 Report Share Posted April 1, 2012 grind till it fits Quote Link to comment Share on other sites More sharing options...
DirtDiggler69 Posted April 1, 2012 Author Report Share Posted April 1, 2012 GITRDONE!!! Will do Quote Link to comment Share on other sites More sharing options...
DirtDiggler69 Posted April 1, 2012 Author Report Share Posted April 1, 2012 Here's the new shocks , yellow wasn't my 1st choice , I'll toss on some black covers . Quote Link to comment Share on other sites More sharing options...
Nightmare Posted April 1, 2012 Report Share Posted April 1, 2012 Quote Link to comment Share on other sites More sharing options...
DirtDiggler69 Posted April 8, 2012 Author Report Share Posted April 8, 2012 I got the front suspension installed today , I have new ASR tie rod ends on the way so next week the shee will be back on her feet . The YFZ shocks are a tight fit but everything slid together nice . Quote Link to comment Share on other sites More sharing options...
DirtDiggler69 Posted April 8, 2012 Author Report Share Posted April 8, 2012 Quote Link to comment Share on other sites More sharing options...
So Cal Suspension Posted April 8, 2012 Report Share Posted April 8, 2012 Did you happen to notice that your spring is touching your upper a-arm? Quote Link to comment Share on other sites More sharing options...
DirtDiggler69 Posted April 8, 2012 Author Report Share Posted April 8, 2012 Did you happen to notice that your spring is touching your upper a-arm? Hard to see in the pIcture but there is very minimal clearance , It has about a 1/4" of space .The other side is the same . Quote Link to comment Share on other sites More sharing options...
DirtDiggler69 Posted April 19, 2012 Author Report Share Posted April 19, 2012 I got the front end all together and the YFZ 450 shocks clear everything , my a arms I am sure are ASR +2+1 standard travel . The Shocks were a tight fit and at full extension the spring does touch the a arm where the heim is threaded into , but no binding at all . I got the shee back on her feet and ran the front suspension up and down and found no problems . I can't wait to carve some dunes and trails ! Quote Link to comment Share on other sites More sharing options...
reneg505 Posted November 17, 2013 Report Share Posted November 17, 2013 How long are the shocks? Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
joey83 Posted November 17, 2013 Report Share Posted November 17, 2013 This is an old thread. I did this swap on my first banshee and it was a disaster. Read around on here. I wouldnt do it! Quote Link to comment Share on other sites More sharing options...
dave5.0 Posted November 17, 2013 Report Share Posted November 17, 2013 Crazy bumpsteer at full droop unless the arms are set up for that length shock. Quote Link to comment Share on other sites More sharing options...
quadgod211 Posted November 18, 2013 Report Share Posted November 18, 2013 (edited) I don't have any problems with mine on +2 +1 arms...no rubbing at all either way up or down....had works dual rates non resi and these seem just as good...cant tell I swapped really Edited November 18, 2013 by quadgod211 Quote Link to comment Share on other sites More sharing options...
